Question about Whirlpool Dryers
Whirlpool commercial gas dryer
Dryer runs fine but will not shut off. open the door and it stops but close it and I continues to run.
Inserted a coin, but no power indicator light (or power ) on.
What is the problems?
Posted on Dec 25, 2009
    Genius:
  • 1,028 Answers
Replace push to start switch
Posted on Aug 30, 2008
My whirlpool gas dryer stops running.It stops with heat or no heat.I have held the door switch with the door open and it still stops.Sometimes it will run a minute sometimes a few seconds
If it runs when you hold the switch but intermittently when the door is closed, you might need to either replace the switch or the toggle on the door. See if you can bend or adjust the toggle on the door that closes the switch to fix it or if you can't, try replacing it first since it is the cheapest solution. Switch, based on what you posted, sounds fine. Who knows, maybe one is simply depressed from slamming the dryer door closed too many times?
Jan 15, 2018 | Whirlpool Dryers
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Aug 23, 2009 | Whirlpool LGV4634JQ Gas Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Kenmore Dryer won't stay running
You need a new thermal fuse. The fuse is located on the blower wheel cover. This fuse cannot be re-set. Replace if open (there is no continuity between terminals). Part number is AP3132867. It is a Whirlpool part but it is the one that fits most if not all Kenmore/Whirlpool dryers.
Dec 08, 2007 | Kenmore 73932 Gas Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
265 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
