Question about Pantech Duo Smartphone
Camra coming up with blank screen
The camra has a blank screen but at the top it still has the normal things (ex. the affects and resolution) its just the view finder that is blank/black... When I look at the lens though it looks fine, the same as ever.
Please help me I'm just a teenager who was afraid of having a smartphone at the risk of breaking it... )-;
  • 1 more comment
  • hunter_x Sep 24, 2008
    no it does not...
  • rsmrostov Apr 09, 2009
    takes forever for a camera to come up and screen is black. Won't take any pictures either...
  • rsmrostov May 11, 2010
    no pictures, it won't take them simply
    Problem Solver:
  • 18 Answers
If you take a picture does it come out normal ?
Posted on Sep 22, 2008
Laptop goes to the launch program and normal start up but when you launch any one the screen comes on and stays blank ?
See if screen is okay when booting to cmos or to safe mode. Can be spyware causing this. Should not affect cmos screen and may not affect safe mode screen (hit F8 repeatedly when booting to bring up safe mode choices). Run Malwarebytes in safe mode.
May 14, 2015 | Computers & Internet
No matter what I try including tool's, I can not get a full screen could you give me some advise please and thank you
Click Start/Control Panel and look for Appearance and Personalization. Open the Screen Resolution. Adjust your resolution and see if that does it for you. Normal resolution is 1024x768 but you can also give it a higher resolution.
You can also get there by clicking Start, then in the search box type resolution. Look at the top for the returned search results and click Adjust Screen Resolution.
May 18, 2012 | Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
The screen resolution is kinda messed up (1680x1050) all the icons have gone much smaller than they should be, the icons on the side in the windows sidebar are smaller than normal. Also it seems to be...
install an AGP card in the AGP slot (accelerated graphics port) then you can see high resolution also you can play '3D games 'and look 'HD video' but internal display card of the 'motherboard 'does not support the high resolution because of the insufficient memory . use ' 8X AGP card' for the better result .
Apr 20, 2010 | HP w2207 Monitor
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Mar 05, 2010 | CTX S762A 17" LCD Monitor
After trying to change the resolution on my monitor to maximum screen resolution it has just gone blank. the start up menu works ok but then when desk top and start menus should come on the screen is...
Move the mouse so it is way, way down in the lower right corner. Place a penny or dime on the mousepad touching the upper left corner of the mouse. Pull the mouse diagonally down to the right a distance equal to the diameter of the coin. Then back up to the coin.
Right Click
Take your hand off the mouse because the rest is on the keyboard.
up <arrow>
hold <Shift> press <Tab>
right <Arrow> 10 times.
left <arrow> (decreases resolution, right arrow to increase)
By the by if you can find a monitor that will accept the resolution you selected on the 'Properties' window you can switch it back the normal way
Aug 04, 2009 | HP Pavilion F1523 15" LCD Monitor
Blank Space Around Screen
Reduce the resolution a little.
Sep 20, 2017 | Acer H233H bmid Monitor
Evo N600C screen smaller than whole monitor screen
This is not a resolution problem.
Instead press Fn - T at the same time. This toggles between the normal mode and the 'minimized' mode. I am not sure why you ever want this smaller mode though. My wife accidently did the same thing you did. It took a little while to figure it out since it also affected the screen size even before Windows 'kicked in'.
Mar 09, 2009 | HP Compaq Evo Notebook N600c
Screen blank
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
Nov 29, 2008 | Computers & Internet
Pantech Duo Smartphone Logo
55 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
