Question about Cameras
Camera on dock wopn't charge - Cameras
  • 1 more comment
  • butchnella Aug 29, 2008
    Already cleaned everything with alcohol.
  • butchnella Aug 30, 2008
    I've determined that it is the dock not the camera. I've cleaned every bit with alcohol.Where can I have it repaired if the cost isn't more than the dock?
    I agree with you. It has to be inside the dock, and I'm sure it would cost more.
    thank yuou.
    Master:
  • 638 Answers
This issue will give you major problems further.so buying the new camera is very much advisable..still if u want to repairit .on the home page of fixya site.there is a repair service column just insert your proper zip code.and you will receive the nearest repair center adress and phone numbers.contact them.and take the proper estimate of reparing the unit.for any thing else let me know.
thanks.please rate the solution as fixya.
Posted on Aug 30, 2008
    President:
  • 1,263 Answers
Chances are either it's a bad contact on dock or the camera you can try and use a Q-Tip and some rubbing alchohol to clean the contacts if this doesn't work check the chord to make sure there is no damage if this is not the case it will be something internal inside the dock and it would cost more to repair than to replace. if you have not had it long check to see if it is under warrenty. good luck please rate this solution thanks
Posted on Aug 29, 2008
    Genius:
  • 1,269 Answers
Check charger terminal and clean it. Also, the battery terminal clean it as well with alcohol.
  • 13,433 Answers
Hey,
Try another set of batterys.
  • Ekse Aug 29, 2008
    More details on your product would be helpful
    Thanks,
    Ekse
How do charge the camera
you do not charge the camera !
You have to charge the removable battery in the charging dock.
it is then placed on the charging dock that is plugged into the power outlet.
The battery needs to be slided in the direction of the arrow on the charging dock.
The battery is located in the camera at the back near the bottom of the camera.
http://www.nodevice.com/download/user_manual/panasonic+nv-vz1.html
Jun 27, 2015 | Panasonic Video Cameras
Camera wont charge
Hi, if you are using the KLIC-5000 battery try to clean the metal contacts on the battery. Try also to remove the battery of your camera dock your camera on the docking station then turn on the camera, if the camera will not turn on it means the charging mechanism of the dock is defective. Now if the camera turns on it means the battery is defective that is why you can charged it.
Feb 11, 2010 | Kodak EasyShare Z760 Digital Camera
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Apr 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Recharge batteries in camera on g610 printer dock?
Hi, I think I can answer your question, i just tried something with my camera and camera dock.
My camera came with a Kodak battery pack(pack that looks like 2 batteries connected together). When I place my camera with this battery pack in it on the dock, a green light comes on on the dock and the batteries begin to charge. However, when i place any other rechargeable batteries in the camera on the dock, it has no effect, my theory is that it must be a battery pack, possibly by the same manufacturer so that it will charge correctly
Dec 20, 2008 | Kodak EasyShare C613 Digital Camera
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
When I put camera on docking it win,t show charge
First, the dock will charge only the batteries that came with the device; not other rechargeable batteries.
Be sure that the Kodak battery is inserted correctly, the door is closed securely, and that the camera is securely seated in the dock with the power cord secure to both the dock and the AC outlet. The USB cord does not supply power to the dock.
Hope this helps.
DigiChick
Jun 09, 2008 | Kodak EasyShare CX7330 Digital Camera
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Jul 28, 2007 | Kodak Dock Plus Bluetooth Thermal Printer
When the EasyShare digital camera is not in use, and the battery is fully charged, can I leave the camera (turned off) in the dock?
The EasyShare camera dock automatically stops charging the batteries after it registers a full charge, so it is fine to leave the EasyShare digital camera on the EasyShare camera dock for short periods. However, leaving the camera on the dock for longer periods (days or weeks) is not recommended because this can cause problems with your camera and the batteries.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
