Question about GE Spacemaker JVM1640SJ Microwave Oven
GE counter to microwave oven
Oven is displaying F3 which I assume is a code for the type of failure. Is it dead or can I correct the problem?
  • Iam Mar 31, 2009
    F3 code. Keypad is frozen. Triple beep.
  • GE Master
  • 9,098 Answers
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 01, 2008
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    4 Digit Failure Codes
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    Controlpanel flashes f 3
    You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
    Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Ge microwave jvm 1430 error code F3
    F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
    Jul 17, 2009 | GE JVM1430 Microwave Oven
    F3 Error Message
    the code means this.
    F3 Shorted touch pad panel
    Good Luck
    Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Spacemaker beeping loud and f3 message driving us crazy
    The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
    I recommend calling a service technician to diagnose and repair your oven.
    Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Beeps
    Code F3 on a GE microwave means you have a shorted keypad.
    Please feel free to contact me directly if you need more help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    prototech@usa.net
    Jul 06, 2008 | GE JVM1440 Microwave Oven
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    98 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    D. E. Hev
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
