Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Leaking from bottom
My hoover stamvac leaks from the bottom of the unit. When I turn it back on water sprays out from the sides til whatever collected is gone. check the hoses they're all in good shape. It look like, the water collects where the Stair/
upholstery Cleaning Connection goes. connected it, to see if it still work and no water was coming out at the nozzle, just keep leaking from the bottom.
Thank You for this forum you have on line..
Marcus G 580
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Posted on Aug 30, 2008
Hoover spin scrub leaks when I turn it off
There are a lot of places that it could be leaking. The most common is a valve under the hood.you will have to put water in it and watch and inspect to trace where it is leaking.
Mar 04, 2017 | Hoover Vacuums
Why does my Hoover F5906 Leaks from the bottom?
Water (cleaning solution) is gravity fed to the floor cleaning brushes, but the attachment hose is fed from a small pump. If it only leaks when turned on and operating, check the pump for leaks at the pump itself or the connecting hoses.
Sep 07, 2014 | Hoover F5906-900 Upright Steam Vacuum
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
No water when i start the machine
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x not spraying water
Please check the following with liquid in both tanks.
Nov 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The machine is not spraying water or cleaning fluid out bissell pro heat 2
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Aug 04, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
741 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
