Hotpoint wt960 filter location
Hotpoint wt960 f05 error
  • Anonymous Apr 25, 2009
    Hey,
    Yes I have exactly the same problem in the middle of a wash it popped up saying F05, and my washing was stuck in there.
    Did you find out how to fix it?
barkencoa
  • 3463 Answers
SOURCE: error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Posted on Jan 31, 2010
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima (WT960)
check filter first as the pressure system is connected to the filter
Posted on Jul 06, 2007
SOURCE: Hotpoint WT960 User Manual
Try the following link:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Andrew
Posted on Sep 18, 2008
barkencoa
  • 3463 Answers
SOURCE: removal of the filter from a hotpoint wt960
Filter is located inside large black hose at rear of washer, remove lower rear panel and remove hose, and clean plastic filter inside hose.
Thanks.
Posted on Mar 31, 2009
Hotpoint wt960 keeps displaying f05
Seems that the pressure switch is jammed and so it does not cut off supply or is cutting off inlet water to the washer. Remove the lines to the pressure switch and reset, check the pressure switch diaphragm
Click pressure switch
Error codes for Hotpoint
Jan 20, 2013 | Washing Machines
F 05
Hello,F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Thanks
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
Fit back and test
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius+ washing machine won't drain and got an F05 error code when trying a wash cycle. Initially the inlet pipes had frozen due to the cold weather but it is now taking in water. However it...
Error code F05 means pressure switch jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum
Remove and clean filter in side hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem
Thankyou.
Jan 13, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Coming up on screen F05
Locate and remove large black hose fastened to bottom of drum.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Error f05
Thanks.
Jan 04, 2009 | Hotpoint Washing Machines
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Washing Machines Logo
542 people viewed this question
Top Washing Machines Experts
