Question about Kenmore 98702 Stacked Washer/Dryer
Wont fill and agatate
I have a Kenmore stackable it just stoped filling and wont agateate.It will spin only ,and dryer is still oprable
  • Anonymous Mar 18, 2014
    tried running diognastic and it did every thing exsept spin.
  • 943 Answers
Sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Posted on Sep 14, 2008
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
My 80 series dryer stopped spinning but still heats
First check the lid or door switch. If it don't agatate or spin check the coupler . Could maybe be a brake problem. Hope this helps
Nov 26, 2011 | Kenmore 64952 Electric Dryer
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Kenmore 98702 Stacked Washer/Dryer Logo
127 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
