Question about ASUS P4V8X-X Motherboard
Problem how i can find my motherbord bios in the internet and how i can update my motherbord mother bordis p4v8x-x-uay0z
    Brigadier General:
  • 5,158 Answers
You don't really help here but just refer to manufacturer website and that we already know =S
so is there any solution ? close your forum please ! you're not helping at all
Posted on Sep 15, 2008
Asus p4v8x-x bad bios checksum checking for floopy floppy not found checking for cd-rom start reading P4V8X-X.ROM could not find P4V8X-X.ROM
Hi, you can download the bios file here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4V8X-X&p=1&s=15
Please select your windows version.
Select bios and click on global for download.
You have to unzip the file before you install it.
You might have to change the cmos battery out with
a new one:
ghost2233_59.jpg So the bios can remember its settings.
Thats why you get a bad bios checksum.
A reminder flashing the bios with a wrong one WILL destroy the mainboard.
Sep 12, 2011 | ASUS P4V8X-X Motherboard
Asus motherboard bios recovery
Ekse
Rank:guru_s.gif Guru
Rating: 85%, 1169 votes
In the disk you burned, the bios can't read a zip file, the file needs to be extracted and as far as I remember you need to use a diskette instead of a cd. but I will look into it now.
Comment by Ekse, posted on Aug 07, 2008 Bios warning
Please note, BIOS update is only recommended when experiencing technical difficulties with your system, And is not recommended to be performed regularly.
Moreover, due to the nature of BIOS update, there is certain level of dangers involved. BIOS update must be performed with extreme caution . During BIOS update process, your system must be maintained without interference or power loss to prevent unexpected damage.
In case of BIOS update failure, please follow instructions in your User's Manual for guidelines on BIOS recovery via CrashFree BIOS. In the event that BIOS recovery is not recoverable via CrashFree BIOS, please contact your place of purchase for further assistance on BIOS recovery.
Source Asus
You can get the bios from here
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
Get the 1008 version
its under Bios and 3rd entry, all os version 1008
File is in zip format, needs to be extracted.
the rom file inside needs to be placed in a diskette.
Comment by Ekse, posted on Aug 07, 2008 Diskette or if you can get the bios to read a cd then that is fine also. Comment by Ekse, posted on Aug 07, 2008 if the setup is looking for a file named as
P4V8X-X.rom
it may be required to rename the PV8XX08.rom to P4V8X-X.rom
But im not perfectly sure what you are trying todo or why it is asking for it. il have to look into this more. Comment by Ekse, posted on Aug 07, 2008 As I suspected, BestDarnGood linked us the manual and the correct page about the problem. it confirms that the file has to be renamed and placed in a floppy.
Thanks BDG
http://www.fixya.com/support/p362915-asus_p4v8x_x_motherboard/manual-11149/page-39
Aug 07, 2008 | Computers & Internet
Asus p4v8x-x bad bios checksum checking for floopy floppy not found checking for cd-rom start reading P4V8X-X.ROM could not find P4V8X-X.ROM May i know what's wrong with it? i've rename the .rom file...
This problem could be caused by a near flat BIOS battery. Replace the BIOS battery and go into the BIOS configuration and set the Date and Time etc.
Apr 11, 2011 | ASUS P4V8X-X Motherboard
New sata harddisk not detected
The mother boards from that time you had to install the RAID drivers to use SATA drives. The drive disc which came with the mother board should have the drive, but I would suggest going to ASUS's web site and download the latest drivers. Click the link below, Select which OS (Operating System) you are using, Next click the little + box next to "IDE" and the drivers needed will be listed.
http://www.asus.com/product.aspx?P_ID=xCBogxJhh6yWBQRi&content=download
Jan 26, 2010 | ASUS P4V8X-MX Motherboard
RESET BIOS ON SATELITTE A100 TOSHIBA?
or reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Jun 17, 2009 | Computers & Internet
Bios flash
firstly i want to tell you that every motherbord bios has a unique program to control the devices.
it this bios is fit on another board casing then you try to firstly run the mother board with old bios. then copy the bios code by any flashing tool and then remove this bios and fit the dead mother board bios in the casing then flash it and then update it which file you copy the old one.
then your motherboard perhaps go on with the dead motherboard bios.
thanks
ramesh
Oct 16, 2008 | Intel D865GBF Motherboard
THE BIOS NEEDS REPAIR
You can download the Bios file from the following link and extract ROM file to a floppy disk. Insert the disk into FDD and follow instructions.
http://support.asus.com/download/download_item_mkt.aspx?slanguage=en-us&model=P4V8X-X
Jul 14, 2008 | ASUS P4V8X-X MOTHERBOARD...
ASUS P4V8X-X Motherboard Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
