Question about Toshiba PDR-3330 Digital Camera
Using Flash When should I use the flash?
    Novelist:
    Scholar:
  • 104 Answers
The Flash is useful up to approximately six feet, after which distance the light is less effective. The Flash is good for close subjects in low light. The Flash is not good to use when taking pictures in large rooms with low light or night / evening scenes. When the Flash is used, the shutter speed is automatically faster to compensate for the light from the flash. This means less natural light through the lens. This can cause dark images in large rooms or evening scenes. In this case, TURN OFF THE FLASH and allow the shutter speed to automatically slow down to adjust for natural light. Your images will be more bright. Be careful, slower shutter also means more potential for blur from motion by you or your subjects.
Posted on Sep 11, 2005
SOURCE:
How do i flash my nokia 6300
You can go to store and flash it using software...
Sep 11, 2011 | Nokia 6300 Cellular Phone
Flash player dont played any vedios
Flash Player is for playing Flash files only and not any other video formats. Are you using the Flash Player plug -in or add-on for the browsers or you are using a standalone Flash Player?
Flash Player plug-in or add-on for browsers is for playing web flash content files. If you want to play any flash files eg .swf , then you can open-with the browsers.
Standalone flash player is used to open or view any flash files, it is not meant for web embedded flash files.
Hope it helps.
Jan 26, 2011 | Computers & Internet
I want to install adobe flash so that i can preview 123 greetings for christmas
1. Using Internet Explorer to view your flash files, install Flash Player 10.1.102.64 (IE)
2. Using other Browsers to view your flash files, install Flash Player 10.1.102.64 (Non-IE)
3. When playing web games you may need to install, Shockwave Player 11.5.9.615
Just install the three installers if you are using Windows Operating System.
Hope it helps.
Dec 01, 2010 | Adobe Flash® CS3 Professional Full Version...
I have this Electro GSN one. When I mounted a normal flash, the flash doesn't function. What is the solution? Does it need a special flash which differently? Thanks for your helps. Reap
You can use any flash that has one contact at the shoe.
Try using the PC flash cord to the flash socket on the camera body and see if the flash fires. If you see flash with pc flash cord and not with the accessory shoe, try cleaning the flash contacts at the hot shoe.
If no flash either using the hot shoe or the flash cord, try testing the flash. If the flash is good, you have to open up the camera to trouble shoot. The flash wire is connected to the shutter's flash contacts.
Jun 01, 2010 | Photography
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
Kodak es c875 flash problem
Try to do this press the flash button then chose the Fill Flash so if you take picture it will always fire the flash., May be your using the Auto Flash.
If your flash will not fire using the Fill Flash setup it means the Flash is defective call tech support toll free 1 800 235 6325 ext 12
You may also see the flash setting if you press the menu button and under menu button look for setup
Nov 15, 2009 | Kodak EasyShare C875 Digital Camera
Nikon D90 rear curtain sync will shoot flash twice
That is most likely the TTL preflash and should not show up in your final exposure.
Try setting the flash control to manual (e2 under the Bracketing/Flash menu). That should give you only the one flash at the end.
Aaron Gum
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
Maximum flash sync
I have a 3000z, and have not noticed any problem with flash sync with even the fastest speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Toshiba PDR-3330 Digital Camera Logo
50 people viewed this question
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
