Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
No image from inputs 1 and 2
No video signal from inputs 1 and 2 (both RCA and S-video). Audio signals are commutated properly. Computer image from input 5 (PC VGA connector) works.
  • american_jes Jan 06, 2009
    Nothing from imputs 1 or 2...rest work fine.
I just spoke to a tech guy and his solution worked for us. turn everything off including the dvd player or whatever you have in your video inputs.
pull the tv power cord out from the back for 30 seconds. plug the cord back in. turn on the set for 30 seconds. then turn on your dvd player. you should now see a picture.
we had something funky happen to our cable the day the set starting giving us trouble. pulling the power cord apparently allows the tv to reset.
good luck.
Posted on Feb 07, 2009
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
I have 21 GOODMANS LD2212 TVs and want to play an MP3 player through the "audio in" however it shows no AV signal (yes I have selected AV or SCART source) likewise if I use a scart and connect...
From your description, it seems like the set doesn't activate the AV input unless it sees a video signal. I don't know if it the input is smart enough to require a valid composite signal (that is, one from a source that includes proper synchronizing signals) or if it will work as long as something is there. So here's a suggestion. Get an RCA Y-adapter with one jack in and two plugs out, and split one of the audio outputs from the MP3 player. Feed the audio to the audio input as normal, and connect the other plug to the video input. This may enable the AV input since there will then be some signal at the video input. It won't be a valid video signal, of course, so if it works you'll just see random flashing on the screen. Maybe you can pretend it's a light show to accompany the music.
Mar 30, 2011 | Goodmans Televison & Video
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Nov 28, 2008 | Initial DTV-171 17 in. TV/DVD Combo
Component input- no audio/video signal
what aiudio cable uusing with couplunt cables red white on same input ?
Oct 07, 2008 | RCA P61310 TV
Vga audio in
VGA does not provide sound, only video signal.
to get sound, you need to run a signal from the audio output of the computer (1/8" mini) to the audio in of the TV (RCA).
Sep 06, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
Video input problems
If its a brand new set and never worked from the get go I bet ya 10 to 1 that theres a plug or clip lose in the set someware. Hope ya got a warrantee as you should have unless you bought if off A corner someware. Call the repair service # thats in the owners manual to get it fixed asap. Good Luck
May 27, 2006 | Toshiba 46HM95 46" HDTV
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
186 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
