Question about Philips Audio Players & Recorders
Philips cdr 765 cannot record blank cd
Philips cdr 765: Online, I purchased a pack of TDK's audio cd-rw for the recorder. Recorder will not record the blank cd and the door won't open ( I opened it only after endless times pressing the open/close button). Like the right side tray, the
left side has no problem playing or opening the door when a pre-recorded cd is inserted.... can u please tell me if this can be fix.. by the way, I have already atempted to fix it by cleaning the laser with a cotton swab and alcohol, Thankyou.. mario
5 Suggested Answers
  • 112 Answers
SOURCE: TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Posted on Feb 20, 2008
SOURCE: Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Posted on Dec 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a philips
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Posted on Jan 30, 2011
skywavebe
  • 1252 Answers
SOURCE: Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Posted on Dec 11, 2012
gopakumarg43
  • 69610 Answers
SOURCE: my home theatre sony dav tz135 cant open the cd tray is locked as displays when i try to open it pls what can i do help please
Visit the site linked here. Tray unlock procedure to Sony decks are given. http://electronicshelponline.blogspot.com/
Posted on Jan 07, 2017
Having difficulty locating cd-rw's that will work in my philips cdr765 recorder
I hope you're looking for CD-RW DIGITAL AUDIO blank media. Try eBay.
Jul 06, 2011 | Philips CDR765 2-Disc CD Recorder
NECESITO EL PLANO O DIAGRAMA ELECTRONICO DE EL EQUIPO -PHILIPS AUDIO COMPACT DISC RECORDER CDR 765. DESDE YA, LES AGRADEZCO SU ATENCION CARLOS CISNEROS
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
Jun 17, 2011 | Philips CDR765 2-Disc CD Recorder
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
The manual:
Discussion online:
good price..."
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
Have not been able to find digital cd's. Are cd audios the same for use on philips 870
Philips CDR 870 is designed to RECORD with ONLY Audio or Music CD-R or CD-RW discs !!
The word(s) Audio Or Music MUST be written somewhere on the Cd disc or Cd Covers.
Computer CD-R and CD-RW discs will NOT Record on this recorder !!
My experience of GOOD Audio/Music discs : Philips,Sony,Traxdata,Verbatum
My experience of BAD Audio/Music discs : ALL unbranded discs, Maxell,TDK
Dec 16, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Philips cdr 760 cd recorder: OPC FAILED
I have a Phillips 775 CD Recorder, and can only get it to record using Maxell CD-R Music Pro brand blank discs. They usually come in packs of 10 and are in full-size jewel cases. Haven't bought any in awhile and am not sure about availability.Hope this helps.
Jun 23, 2008 | Philips CDR760 CD Player
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
NO RECORD
This message usually indicates that a non-audio disc is in the record tray. Please use only blank music CD-R or CD-RW media. Refer to page 12 of the owners manual for more information regarding acceptable media type for the DA-3826. Also, the laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a CD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 07, 2005 | TDK DA-3826 2-Disc CD Recorder
170 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
