Question about Toshiba PDR-3330 Digital Camera
Using the Remote Control
How do I use the remote control?
    Novelist:
    Scholar:
  • 104 Answers
With the camera turned ON, Press the TIMER button and select two or ten seconds. The camera will remain ON and you can use the REMOTE CONTROL to take pictures or start recording AVI Movies. You do not have to reset the camera, just press the remote control again to continue taking several images. Now you can be a part of the action and pictures.
Posted on Sep 11, 2005
SOURCE:
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
How to make my philips DVP3747 region free
Here is a hack that I've found to work on many Philips machines.
Turn on Player
Using Remote Control open the Disk Tray (and leave open)
Using Remote Control Press SetUp
Using Remote Control Scroll To Preference using Left / Right Arrow keys (Just Highlight it do NOT select it)
Using Remote Control Press 1 3 8 9 3 1
Region Menu Screen Should Appear
Using Remote Control Select Desired Region Using Up / Down Arrow Keys (0 [Zero] For Region Free)
Hope this helps.
Jun 18, 2011 | Televison & Video
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Philips DVD player dvp 3580 regional unlocking code needed to play region 1 dvd.
1. Press the Setup button on your remote control
2. Using your remote control, highlight but do not
select the Preferences menu
3. Press the 1 button on your remote control
4. Press the 3 button on your remote control
5. Press the 8 button on your remote control
6. Press the 9 button on your remote control
7. Press the 3 button on your remote control
8. Press the 1 button on your remote control
9. Using the Up and Down buttons on your remote
control select 1 for region 1, 2 for region 2, and so on, or
0 for multi-region playback
10. Press the OK button on your remote control
11. Press the Setup button on your remote control
May 05, 2010 | Philips Televison & Video
Menu display un readable , can not go higher than 69 with remote, ch keys will not change ch on remote or tv , game display works. need help with set up?
try using the numbers of the remote control, for example, if you want to receive the channel 105 intro in your remote control using numbers 1,0,and five next push enter button of the remote control. Another thing, be sure that your tv is in mode cable or antenna, some remote control has this option in his buttons, see on your remote control.
Mar 17, 2010 | Durabrand DWT1304 13" TV
Toshiba PDR-3330 Digital Camera Logo
Top Toshiba Cameras Experts
Damen Wong
Damen Wong
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
