Question about Canon ZR80 Mini DV Digital Camcorder
Blue Screen or Pixelated on Playback
I have a blue screen or pixelated/distortated playback. I have tried a head cleaning cassette. It seemed to work, but within a few minutes after cleaning it returned to its original state. I tried the head cleaning cassette again but I have not seen further improvement. Is it possible to clean the head myself? Or could it be a different problem?
Check Canon's Website. There's a known problem with video chip on several different models...including zr80...a loose connector from the CCD.
I know what I'm talking about because I just got one fixed...for FREE.
Posted on Sep 09, 2008
My sony trv460 only shows blue screen on playback - first it was skipping - I bought head cleaner but the camcorder does not run it - I have tried using alchol with cotton to wipe directly, but still
You can also try blowing compressed air similar to what you use to clean your keyboard. It can often dislodge any particles that impede the heads from spinning properly.
Jul 03, 2012 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
Jan 27, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
TRV460 on playback will turn on and off
I think camera has problem of dirty / clogged video head.
please use Sony video-8 head cleaning cassette.
Sep 27, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Won't playback
Use good quality video head cleaning cassette because video head seems dirty/ clogged. If it doesnt solve the problem, video head need to be replaced.
Jun 25, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Distorted pixelated image on right side
pixelation on the right side is an indication of misalignment of the exit roller.  don't try to align it yourself unless you're experienced in this repair.
Oct 10, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Problem with blue screen on my SharpVL-AX1 camcorder-video+playback does not work, but I can take still images with no problem
a simply cleaning of video head will solve the problem. if the head clean cassette is not working try doing manualy or get it done by some expert.
Jul 02, 2006 | Sharp VL-AX1 Mini DV Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon ZR80 Mini DV Digital Camcorder Logo
376 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
