Hp pavilion zv6100
How can i restart my hp pavilion zv6100 bqck to new again. i dont have the cd or my restore point does not work cause it was not enable. i know some computers u can press control and f7 and it will reboot it self is there something like that that i can do?
    Genius:
  • 2,028 Answers
This model doesn't have a built in recovery feature that some machines have, so you will need either an operating system disc or an HP operating system recovery disc in order to reload the system to factory original status. I'm sorry, but there is no other way around it.
Posted on Aug 29, 2008
Well i start up my comp and errors pop up i dont know how to fix
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 11, 2013 | HP Pavilion dv6000z Notebook
Hp pavilion will not boot, error0xc0000409
Step 1:
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 03, 2013 | HP Pavilion dv7-1245dx Notebook
Tva agent.exe.entry point not found
In fact TVAgent.exe is a component of Hp software, but it seems your's a little different, as you've mentioned as TVA Agent.exe. Anyway, you can fix this, but you have to troubleshoot what exactly is causing this problem, after you find out the culprit, you can disable it.
I assume you are using Microsoft Windows XP, click Start > Run > and then type in "msconfig.exe" [without quotes], press enter and again click "Startup" tab on the new windows, now click "Disable all" and restart your computer, this time you may not see the error message. Now open the msconfig once again, enable few of them, click ok and restart your computer and check if you see the error again. Keep on enabling and restarting your computer until you find out the culprit and leave it disabled while the rest are kept enabled. This will fix your problem.
This is sometimes caused by virus/malware/spyware, so you also need to run a full virus scan to make sure it's not infected, use avg free and avira free to scan. You can download them from their respective websites.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
Sep 18, 2010 | HP Pavilion dv9000z Notebook
My sound is not working
You can try a system restore to get back to a point when the problem with sound was not there. To restore:
Click the Start button, click All Programs, click Accessories, click System Tools, and then click System Restore.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click on Choose a different restore point, and click Next. You will see a list of restore points. If you find the date when the sound worked then click on it and click Next. Otherwise click on the check box Show restore point older than 5 days, and then select your preferred date.
The system restore will take a while to complete, when it does, your computer will restart automatically..
When it starts again, see if the problem remain
Jan 29, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv6208nr Laptop will not boot into Windows. Screen is black. Laptop continuously tries to restart, unsuccessfully.
Try run windows in safe mode then restore your win from a restore point,if that doesn't work then reinstall windows.
Jan 24, 2010 | HP Pavilion dv6208nr Notebook
No output from CPU - led lights up, CD drive
Just for a chance , can you press f8 before it loads windows or alt and f12 or f12 by its self to give u a system restore setup, or a last known good confirutation options, hope this helps in some way, remember keep pressing either of these just before the point it goes to load windows, strait before bois screen goes.
Dec 04, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
Reset the password for hp pavilion entertainment dv4
i dont know if this will work, restart and press f8, enter safemode and you will see 2user option, select which one will make u able to log in, if this successful,
1. system restore: restore your computer on the date before he reset the password
or
2. open control panel and create new account
the last option is format it and i know you don't want to do that.
Jan 28, 2009 | HP Pavilion dv4tse Entertainment Notebook...
How can i reboot my hp pavilion zv6100 back to brand new when i first bought it. i dont have a restore cd that came with the computer. is there another way that i can do this or not?
The restore disc is the best way, however, you can do a system restore from the system tools in the accessories section of the start menu. There should be a restore point either the day it was first loaded or close to the day, if not, then choose the earliest restore point. This will get you real close to how it was when you first got it. It may leave a few programs or files that you added since having the machine, and if you do not want anything left, then you will have to remove them manually. If this is helpful or better, rate me accordingly, but please do not rate me if you feel this doesn't deserve at least helpful.
Aug 26, 2008 | Computers & Internet
You can use the HP recovery disc that came with your laptop to bring it back to its original settings.
Aug 25, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
