Question about Optoma H30 Multimedia Projector
Optoma projecter My projecyer is mounted on the cieling and it always turns off after 1/2 hour or so. What is wrong with it
  • 286 Answers
It is most likely getting too hot.
Make sure all the fans are clean. Make sure the projector is not mounted too close to the cieling. This may block vents in the housing.
If you have to, you may need to mount a small fan near the projector to blow into the vents. Make sure it blows in the right direction. You don't want it working against the fans inside the projector.
Just for a test, unmount the projector and run it on a table. This should tell you if the mount on the ceiling is causing the problem.
Posted on Nov 04, 2008
My Optoma ES522 keeps blinking all the colors of the rainbow and then going to grey. I have to turn it off four hours to even get it to start up again and then sometimes within minutes it happens again....
It seems that's the color wheel problem. You can fix this by your own. Probably the dust covered the color wheel sensor so it doesn't spin at specific speed.
And the project is now telling my lamp is at the end of it's useful life. How much will it cost to replace that?
You can switch off lamp reminder in OSD menu settings. This reminder is usually set to approx. 1200+ hours. When you exceed this limit, reminder starts to pop up. Actually it doesn't tell anything about PJ's lamp condition. So that doesn't mean that something is wrong with your lamp, maybe it lose some brightens, which is typical phenomena wheen exceeding half of lamps lifetime.
GENUINE new lamp costs around 160-180€, COMPATIBLE COPY should cost around 100€ +
Dec 20, 2010 | Optoma ES522 DLP Projector
Optoma HD81-LV ... white lines on projected image
this has happened to many of these tvs, I would return it if you can, this isn't worth it to get fixed. I'm sorry if you can't return it, yours lasted less than many I have heard of
Mar 25, 2008 | Televison & Video
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
Display is faded and remote not working properly
Despite the "hours left" on your projector, the lamp could be nearing the end of its life. Recommendations:
1. Make sure the vents and filters (if applicable) are clear of dust and debris.
2. Make sure the projector is well ventilated. (i.e. no obstructions around the vents)
3. Replace the lamp. They're around $200 on eBay. After replacing, reset the lamp timer (see your manual).
4. After replacing, run the projector in eco-mode if the brightness is acceptable. This will extend the life of your lamp.
5. Always let the projector cool down before unplugging the power or turning the master power switch off.
I don't know what would cause the inability to access all the menu options.
Hope this helps somewhat.
Apr 20, 2009 | Audio Players & Recorders
Want to clean inside of tv want o hook up cieling speakers
Distance of where the ceiling speakers are mounted and where the TV is a factor. Sounds takes time to travel through the air. What you are hearing is a time delay most likely. Hope this helps.
Apr 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
Need new power supply for rd 65 optoma tv
try callin 1-888-289-6786 .. thats the number for optoma
Jul 09, 2008 | Optoma RD65 65" Rear Projection HDTV
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Optoma H30 Multimedia Projector Logo
65 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
