Question about Lexmark C530dn Laser Printer
Grey background We have a new Lexmark C530dn that is printing a grey background on every page. It is especially bad on envelopes where the pattern of the fold from the back side shows up as an even darker background on the printed side. It looks like a mostly even "mist" of toner across the page.
  • ebby409 Feb 02, 2009
    I have the same "grey" background problem, especially on envelopes; when it is near time to replace the black cartridge, it gets even worse.
4 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Posted on Sep 22, 2007
  • 27 Answers
SOURCE: My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
Posted on May 17, 2009
  • 1684 Answers
SOURCE: The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Posted on Jun 19, 2009
HansPP
  • 2510 Answers
SOURCE: There is a faded blue strip on the left side of
Any marks on the paper come from the drum, this could be a circumferential scratch on the drum or a void in the wiper that clears the excess toner. Whatever, you need to check the drum and possibly need to replace it.
Posted on Jan 28, 2011
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Printer leaves look of burn marks as granular shadow over page
Sep 22, 2007 | Lexmark C524 Laser Printer
Recently ,after buying new 1 month ago, I get rectangle dark grey/light grey blotches printing on the page at various places,as a background,as well as my normal printing.How do I resolve this
The firmware update for the Lexmark Pro901 will help fix this problem. Visit the Lexmark website at http://bit.ly/p905fwto download and install the update. Running the "Deep Clean Printhead" maintenance will also help.
Source: There is a Problem with the Printhead
May 23, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
There is a faded blue strip on the left side of every printed page from the lexmark C530dn laser printer. I do I clean it to remove this line?
Jan 28, 2011 | Lexmark C530dn Laser Printer
The pages come out with a grey tint. Can I clean
Remove the toner - using a can of air blow the printer out. I would really suggest after that trying a fresh toner.
Jun 18, 2009 | Lexmark C530dn Laser Printer
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Background
You need to clean nozzles. Go to canon tools and find clean nozzle option. Perfor operation a couple of times, just in case.
If this does not work you will need to open your priner, physically clean heads with a cloth. After this you may need to empty the waste ink tank inside the printer and eventually change the sponge inside it.
Hopefully we are in first scenario and you will fix it doing a simple nozzle/head clean from canon software in windows, without disassembling the printer.
regards
Mar 02, 2008 | Canon PIXMA iX4000 InkJet Photo Printer
Manual Feed Issue
will not pick up envelopes to print
Feb 09, 2008 | Lexmark C530dn Laser Printer
Lexmark C530dn Laser Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
