Question about HP iPAQ RX3115 Pocket PC
How do i uninstall programs?
I just bought a new PDA (Ipaq rx3115). I tried to install some programs I got from pocketgear. Unfortunately, although they installed, they do not work and I wish to uninstall them. How do I do that?
    Master:
  • 450 Answers
Go to Start > Settings > System > Remove Programs
Posted on Sep 11, 2005
I have an IPaq rx3115 that I baught through amazon used when I charge it through the usb cord through pc or an uviversal plug to plug the usb into the wall outlet only battery that charges is the back up...
send it back
these PDA devices are now legacy, what good is it.
buy a used smart phone,, 10x better, really 100.
end less apps. on cell.
it will need a new main battery and the tiny one too,.
all do this old.,
id send it back.
Jan 28, 2018 | HP iPAQ RX3115 Pocket PC
My ipaq hp pda Rx3115 does not have the right time as my clock does how do i change the time?
Start Menu
--> Settings
--> System
--> "clock & alarms"
There you go. You can even set an alarm. :)
--Eric
Apr 04, 2009 | HP iPAQ RX3115 Pocket PC
Ipaq 3115 screen
You need to open your PDA and check for a false contact between the connectors of the LCD screen and the main board.
Other cause may be that the LCD screen flat ribbon cable is defective.
Either problem requires to open the PDA to check it.
If you have experience in opening electronic devices then you can try it. Otherwise, I do recommend you to have a experienced technician in checking your PDA.
Best regards,
Apr 25, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
INSTALLING
how much did you pay for this pda? did you buy it recently? Is it brand new or are you the second owner?
Aug 21, 2007 | HP iPAQ RX3115 Pocket PC
Can't get dynamic ip address
What about your desktop pc? Have you checked the services on it to make sure it is not broadcasting DHCP? Also, think about switching over to Stealth Mode (Non-broadcast SSID) instead of MAC filtering. MAC filtering can be cummbersome and if it is just you, then do away with it.
Sep 19, 2005 | HP iPAQ RX3115 Pocket PC
Rx3115 instaling programs
The downloaded file has to be executed on the PC I suggest to read "Installing ICQ ..." http://www.icq.com/icqtour/install.html
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HELP Rx3115 today screen help
Did you try doing a soft reset? Switching off and on again does not reset your ipaq. You will not loose any info.
HP iPAQ RX3115 Pocket PC Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
