Question about Intel Motherboard
Microstar ms-7103 (661fm3-v)does not see a sata drive
I have a machine that i need to reformat and put a fresh load of XP pro on. Whenever I boot from xp pro cd it does not see a sata drive.The machine will boot up to that drive. i have looked all over for asata driver to install at the F6 prompt but have found none. Can anyonehelp me out here?
    Brigadier General:
  • 5,158 Answers
The Bios sees my new SATA 750GB HDD but shows it as 0GB in Size and no options to format. XP does not see the drive. How do I format it from the BIOS Setup Menu? It is connected correctly.
so what is the 1st drive, and is it IDE or SATA.
or is one a
why are you using XP is it 32bit or 64? ill answer for 32..
its a dead OS,totally dead,and virus magnet and the MS PnP severs are shut down.
XP also MUST have the SP3 installed or the THING cant find any modern, SATA chips and many other devices.
im looking at your MOBO now,
it has 4 sata jacks
1 floppy
and 1 IDE jack let me guess this is what Drive one, IDE (pata)
is plugged in , then you add a new sata drive to the old sata ports
and XP pukesssss, as all XP does (cept mine)
SSDD. Same stuff different day,
so you can either use w7 like all savvy folks do
or find the driver missing that MS cant find, XP is dead.
but wait XP needs a Floppy drive to load the correct driver.
but if XP is running now, we dont need that only on XP installs.
ive no idea on what sata chip is there, in our shop
we scan it to find that and HP does not tell this.
Pentium D processor
Intel 945G Express
i think this is it , the 945G
load this driver from HP
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-dc7600-convertible-minitower-pc/472276
32bit
File name:
sp38488.exe (2.0 MB)
Nov 16, 2017 | HP Compaq dc7600 Convertible Minitower PC...
How to reformat PC
Boot to your XP Pro OS CD and hit enter to load OS. Hit f8 to accept agreement. Delete present partition and you'll get an option to format the C drive and load a fresh version of XP. If you don't want to load XP again- boot to the XP disk and go into the Recovery console - after logging in, type format at the C: prompt.
Nov 09, 2010 | Microsoft Windows XP Professional
Wants to reformat drive when trying to access.
Install the drive as a secondary drive on known working computer. Go into it via windows explorer, locate and backup the files you want on a usb stick or external hard drive. Format the drive, load your OS, and reinstall the files you saved from the drive before you formatted it.
Apr 10, 2017 | Buffalo Technology 250GB USB SATA 2.0 HD...
Hi, I got a free HP compaq desktop, the small ones, is 2.66hz it was working fine, but i don't have the password for the administrator in a xp pro, so I just reinstall a new copy of XP but now this...
please load xp again and press f 6 when you see it on the screen to load sata devices .
sata softwares and drivers are required in certain computers to load windows so while loading you will be asked to load those drivers through a floppydrive, so u must have
1)sata raid drivers (according to the hard ware installed in hp.)this piece of hard ware will not allow xp to boot if you dont give its drivers through a floppy drive(during installation and setup of windows.
so u must now have
1 floppy drive(usb)
2 a floppy disk with sata drivers
3)usb port to attach the usb floppy drive
after loading xp you will see xp running trouble free.
a easy solution is to load vists and the drivers are already there in vista cd.
Sep 19, 2009 | Computers & Internet
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
T30 wont reformat
download "hirens boot cd" and burn to a cd, select the machine to boot from cd, when boot cd loads, select boot cd, it will take you into a dos menu, select hard drive tools, there are a number of utilities there for you perform surface scans a bad sector checks and repair tools
good luck with it
Nov 17, 2008 | IBM ThinkPad T30 2366 Notebook
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Can't Enter Setup/Can't Access BIOS
Could be that your PATA drive is pooched. Have you tried accessing the bios with the sata drive in, how about with both drives connected, how about with none.
Try a ps2 keyboard as well, as it may work on the legacy bios option.
May 01, 2008 | EliteGroup nForce3-A Motherboard
Boot Failure
i am assuming you have allowed the bios to detect that there is a different hard drive fitted as it will be looking to boot from an non existent drive. If you have fitted a new HDD with an operating system already on it then you will have to repair windows as its a change in hardware. If you cant get the bios to see the drive then the motherboard has an IDE or Sata connector problem.
Sep 13, 2007 | Computers & Internet
Intel Motherboard Logo
2,512 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
