Question about Xerox 3001 Copier
Xerox 3001 Code A6
I recently moved my office, and when I restarted the 3001 the A6 code flashes. The manual says that this code is for feeding the documents in the wrong order, but since I moved I have not used the copier. I have no lights on the board either, just a flashing A6
  • surveyor850 Dec 16, 2008
    I have the same problem. My blank paper will go in fine, but when I insert my material to be copied, the machine draws the paper in about 1/3 of the way then the machine shuts off and the A6 code appears. I have been on the phone with Xerox for 3 days now, and they will not come fix it as it is an older machine. I did talk to a service rep and he thinks it may be a simple fix, but Xerox will not authorize him to come work on it. They just want to sell me a new machine!
  • 67 Answers
A codes are up top. Make sure the switches are not stuck down or broken. Test the machine in the long document mode, that asks for the paper first then the original. Usually an easy fix.
Posted on Jan 10, 2009
FREE SOLUTION NO ROLLER REPLACEMENT
I shifted the flap that runs across the top of the copier (raised it slightly and then slotted it back into position).
Posted on Feb 18, 2010
    Scholar:
  • 136 Answers
Typically this problem is from the Top, What I did for this customer was replaced the lower rubber rollers then replaced the upper spongy rollers especially since if their a yellow color. IUf no one wants to service this engineering copier for you then look us up on the loal repair listing on this site. Name of our company is Copiers Plus Worldwide,LLC. Located in Stratford,Ct we worked on the 2510 lot and these are very very simular.
Look us up we will glad to evie it if your in the area
Posted on Dec 07, 2009
XEROX 3001 - ACCEPTS THE DOCUMENT, BUT DOES NOT ACCEPTS THE MEDIA
press the sets button on control panel then first feed media then feed original
Aug 30, 2010 | Xerox 3001 Copier
Audi A6 3.0 tdi Quattro 2005, glow plug light comes on, limp mode
16619 -Engine boost condition - Limit not reached. Check intake hoses/ connections for leaks. Check Turbo charger waste gate regulating valve/ waste gate working correctly. Must move freely when accelerating, won't achieve full boost if waste gate sticking open. Check Turbo impeller turning freely, oil feed pipe for turbo can get blocked causing impeller to seize. Engine compact, not easy to access these components.
Jun 06, 2010 | 2008 Audi A6
I recently moved and now my dryer is flashing PF
According to Whirlpool, all you need to do for “PF” (power failure),
is check the following:
Was the drying cycle interrupted by a power failure?
Press and hold START to restart the dryer.
To view the owner's manual for your dryer click on this link & choose the model # that you have from the list.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WED8300&siteCd=WHRCOM&userType=Consumer
May 27, 2010 | Whirlpool WED8300S Dryer
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Looking for manual for xerox 3001
Google a business called "the parts drop" . Give Britt a call I am sure he will have one.
Jun 24, 2009 | Xerox 3001 Copier
How to Install a K toner
"K" is the black toner.
Follow this link to a "flash" demonstration on how to change toner (scroll down to the bottom of the page):
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=6115MFP&country=United%20States&language=en
*please rate me :)
Mar 25, 2009 | Xerox 3001 Copier
Xerox Docucolor 2006 Error Code 009-358
Solution Listing for Symptom The Printer's Control Panel Displays 009-358 - Contact Service Solution (try these steps in order) 1. Turn the printer off, wait 30 seconds and turn the power back on 2. The printer will need to be repaired power off the printer and contact service Not good news I am sorry to say. http://office.support.xerox.com/srvs/cgi-bin/webcgi.cgi?new,ques=User_Type:4,templateset=xo_legacy,kb=out98pkb,ques=obj(69892)::obj(707),ques=obj(34668)::obj(67237),Company={5AC8CA72-62D5-4658-8D6F-D2F393C98A63},varset=prod:2006 http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-2006/sprt-enus.html Good luck, Tim
Mar 15, 2007 | Xerox DocuColor 2006DPC Laser Printer
Error Code
Hi, all I know that is something about Xerographic components.
Try to clean printer inside,sensors etc.... and run some user adjustments.
Jan 17, 2007 | Xerox DocuColor 2006NPC Laser Printer
Xerox 3001 Copier Logo
568 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
