When trying to froth the milk, all that is happening is the milk is bubbling and getting heated. i have tried re-priming the system several times, and have tried varying the amounts of milk I'm trying to froth. This machine used to produce a very dense foam but started doing this shortly after I had it repaired for a failed seal that caused water to come out the coffee dispenser. When using the water spout just for teas, it works great.
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
Make sure the edge on the steam pipe are in place.
Posted on Aug 30, 2008
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Jan 25, 2012 | Nespresso Aeroccino Automatic Milk Frother
Feb 13, 2010 | Gaggia Titanium Espresso Machine
May 09, 2009 | Krups XP7225 Espresso Machine
May 03, 2009 | DeLonghi Esclusivo Gran Dama EASM6600...
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Jul 11, 2008 | Saeco Incanto Classic Espresso Machine
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
727 people viewed this question
Hi...I have the same issue. When I first purchased my machine 3 weeks ago it worked perfectly. The froth was perfect...I always keep the spout clean and check the temp of milk. I've tried everything even new containers to froth the milk and nothing works. The steam coming out is very strong as always but when I try to froth the milk it just heats it to the correct temp without frothing any of it. What am I doing wrong? Please help me...thanks beforehand.
Suddenly the machine stopped frothing the milk, though was doing that perfecrtly before. There is good pressure of steam but milk is only getting hot.
In the past I had a problem with the wand, the plastic tube within it was moving and that caused problem with forthing.
I got it replaced and since then it was working perfectly again.
But this time everything seems to be OK, except the fact that it is not frothing the milk.
Nespresso
It's not frothing the milk anymore
