Question about Toshiba e755 Pocket PC
Map Install Having problem of the download being extremely slow. I have approx 150MB of maps on the SD card. Today I selected 4 areas in the Chicago area to download to the ique. That would bring the total storage to 195MB of data per MapInstall. I have a 256K card. The process of the preparation of the install (building indexes ect.) took in excess on 8 mins.
    Master:
  • 903 Answers
The “download” and the “indexing” of the maps are really 2 separate procedures. Yes, the indexing can take quite a while; you might as well have something else to do after you hit OK. Some members save certain maps files, already indexed to substitute as needed. Then the only speed concern is in the copying of the file to the SD card using a card reader. Some cards such as the Toshiba are fast to read but slow to write so this becomes a factor at this point. Edit: I’m assuming you meant 256MB not 256K. Also when you add just a little to your existing map file, it will cause the entire map to be recreated, so it’s not how much you currently add as how big the entire resultant map is that determines the time needed.
Posted on Sep 11, 2005
SOURCE:
I purchased a used sd card western Europa. di i need to activate it and how can i update it
If you insert the SD card into your TomTom device, and you can see it ... as one of the maps on your device ( when you go to Menu ... Change Map ... etc. ). ... try selecting that map, and if it doesn't tell you it is not available or not activated, then you can use it. Otherwise, you need an activation code to activate the map.
If the map on the SD card is a LifeTime map, you can simply connect your device to the tomtom website (using the HOME software), and it will let you know you have an update (of that map) to download and install. Otherwise, you have to subscribe (i.e. pay) for an update of the map.
May 18, 2014 | Tomtom Go 700 Portable GPS Receiver
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
I downloaded a free map upgrade for nuvi 250w. I didn't realise that I'd need an sd card. Now I seem to have lost some european maps. Can I retrieve them?
The problem with trying to put the full map of Europe on the 250 is that it doesn't have enough storage space. You can download the complete map however to your computer. The option to download again is available for approx 30 days. When it's on your computer you can select which maps you want to install to the satnav and install the complete map, if you want, to an SD card. You need a 4 Gb SD card to hold the complete map. To download the map again, to your computer, log into myGarmin. Click on the myMaps tab at the top of the screen. There you'll see the map you downloaded. Under the map name you'll see the word "Details" in blue. Click on "Details" and it will take you to a screen where you have the option to download the map again. When you go to download the map it will by default select your satnav as the destination. Change it to your computer so you get the whole map and you can add or remove maps whenever you want.
You can get more details of how to download the map to your computer at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Jun 09, 2011 | Garmin nuvi 250W GPS Receiver
I am trying to update garmin nuvi 250.I bought nu maps lifetime europe (2011.40) but device dose not have enough space for full coverage region.how much space is needed.If i buy a memory card for the...
The map takes approx 3 Gb of storage space so you need a 4 Gb memory card. When you download the map to your computer run it and install part of the map to your satnav. After this click the start button (bottom left of your computer screen) and find the menu folder "Garmin". In the Garmin folder you'll find "Mapinstall" With the memory card in your satnav, and the satnav connected to your computer run mapinstall being sure to select the memory card as the destination. (It will be by default your satnav not your memory card). When the installation is complete the satnav will automatically switch to the map on your memory card when needed. You'll find detailed instructions of how to prepare the memory card and install the map on it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
May 02, 2011 | Garmin GPS
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
I am trying to download the Mexico 2011 map and the download stops because it states I do not have enough space. They advised a 4 GB SD chip which I purchased and installed. The download still stops and it...
When you go to download the map by default it tries to download it to the satnav i.e. not the SD card. When the website recognises the satnav it shows it in a drop box with a drop-down arrow. Click the drop-down arrow and it should give you the option to download the map to your computer. Download it to the hard drive.
After it's downloaded it may begin the install automatically. If not click the START button on your computer and go to GARMIN. In the garmin menu click MAPINSTALL to begin the installation.
When the install program finds your satnav and you get the option to install the map there again click on the drop-down arrow and select the drive letter of the SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD card.
Before you begin to install to the SD card you should know that it can be very hard to get get the 200W, and other satnavs of the same age, to run the map from SD cards. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down again unless you remove the SD card. I recently had this problem with a garmin nuvi 760 and contacted garmin about it. They told me the problem is that 4 Gb SD cards are SDHC which operate differently from SD. They said to get a class 2 SDHC card. (You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10). Before you install the map format the card. Also use webinstaller to check that you have the latest version of operating software on your satnav.
rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive just as easily if you select it by accident or your satnav.
To update your software you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Class 2 SDHC cards are available on ebay if you can't find one in the shops.
After failing to get mine to work on a class 4 SDHC 4Gb card I followed their instructions and it worked for me. Hope it works for you too.
Oct 27, 2010 | Garmin nuvi 200W GPS Receiver
How do I download maps from the Garmin web site to the SD card in my Nuvi 5000?
To install the map on an SD card you first need to download it to your computer. When you're setting up the download the website normally selects your satnav as the destination. There's a drop down arrow and when you click it you find an option to "update map on the satnav and the computer". Select this option. If the satnav can't take the full map you'll need to select the part to download to the satnav. The full map should download to your computer.
After the download is finished click START on your computer and then ALL PROGRAMS. Click on GARMIN and then on MAPINSTALL. The mapinstall program will also select your satnav as the location for installing the map. When it does click on the drop down arrow and select the drive letter of the SD card. This will install it to the SD card. Note it can take 3 to 4 hours to install depending on the map size. Don't interrupt it while it's installing or you could destroy your satnav.
Sep 24, 2010 | GPS
I would like to know if I can donload maps for europe and where i can get them
Go to www.garmin.com If you haven't registered your sat nav you'll have to do that first and connect the satnav to your computer. You'll have to buy the map I'm afraid as there are no free maps for garmin satnavs. The full map of Europe is around 4 Gigabytes and will not all fit on your satnav even if you replace your home map so I would suggest just buying a map of the area of europe you want e.g. western europe and install it on an SD card. You'll have to install some of the map onto the satnav before you can install the rest of it onto the SD card i.e. select one country, so be sure you have some free space on the satnav. It takes about 3 hours to install not to mention the time to download so maybe it'd be easier to just buy a satnav with a map of europe on it.
Jul 22, 2010 | Garmin nuvi 250W GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Toshiba e755 Pocket PC Logo
216 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
