Question about Pioneer DVL-V888 DVD Player
DVL-V888 has MECHA CPU message
I have DVL-V888 player and when the unit is turned on the message on the screen is MECHA CPU. Does that mean that the unit is hopelessly broken?
    Sergeant:
  • 359 Answers
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Posted on Aug 29, 2008
I insert disc, but after a little while, disc ejects without even playing. Help!
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Jun 14, 2014 | Pioneer DVL-V888 DVD Player
Flash Sum
  1. Have you tried cold starting it; disconnect it completely from the mains for ~10 mins, then reconnect and try again.
  2. It is probably a problem with the EPROM or the CPU. You could try resetting the software by holding in the STOP button while turning on the power to the unit. If that doesn't work it sounds like the EPROM is corrupt or the CPU is bad.
Nov 11, 2007 | Pioneer DVL-V888 DVD Player
I'm looking for the owner's manual.
go please to www.fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
God bless you
Jul 21, 2012 | Pioneer DVL-V888 DVD Player
My pioneer dvl-v888 no power at all.
Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is, if it blows again, you will have a power supply fault. Phil
May 19, 2009 | Pioneer DVL-V888 DVD Player
No power at all.
replaced d105 it shorted
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
DVL-V888
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Jul 26, 2008 | Pioneer DVL-V888 DVD Player
DVL-V888 disk tray
you will have to take apart and see if you can push the disk into position other wise have to take apart tray system and remove disk.
Dec 03, 2007 | Pioneer DVL-V888 DVD Player
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
Pioneer DVL-V888 DVD Player Logo
180 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
