Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-air JRSD 226 side by side Fridge
The fridge side has stopped cooling. The freezer side is fine. I removed the lower left service cover and removed the dust. The fan works fine but is running non stop. Can you advise what I can do next?
Thank you
  • Anonymous Sep 17, 2008
    freezer side still cold but the fridge side is at 58 degrees
  • Anonymous Mar 27, 2014
    I do not know the make yet will look next time I go out to moms, as its her frige. It just runs all the time. I cleaned out all the fuzz and dust out from bottom underneath and back. Seals on frige are fine. She did complain before she mentioned the non stop running that it wasnt staying cool enough. Where is the thermostate located?
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Posted on Sep 01, 2008
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Feb 22, 2008 | Jenn-Air JCD2290HES Side by Side...
Referidgerator side is not cooling?? Help?
I had this problem. Here's what I found: The cooling core on the freezer side was froze up. Covered in ice. I think the reason this happened was that the freezer door was held open by one of the slide out trays just enough to pull in outside air. Don't know how long it was like this. When I found it (and corrected it) the interior of the freezer was covered in ice crystals. From then on the refer side contents began warming up. There was no flow of cool air to the refer side from the freezer side (this cool air comes in from the freezer side fan near the top left side of the refer side). Freezer side was near zero temp and the unit ran continuously. Here's what I did: Removed everything from both sides (put it all in another fridge/freezer). Turned off (or unpluged) the fridge and left it off over night. I put towels under the fridge because there can be an over flow of water that could go to the floor. It works great again.
Nov 03, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
283 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
