Question about Sewing Machines
Sewing machine stops after few stitchesstrikes metal
The bobbin case got all jammed up with thread one day and I had to pull and cut it all out. I was careful and did not damage the compartment in any way....or so I thought.
Now, I can only sew a few stitches and the case stops going around and the needle is striking metal and stops. I align the metal part that goes around by pushing it clockwise just about 40 degrees and it works again for only a few stitches and repeats the problem.
What have I done and can I fix this problem?
It sounds like you have a machine that has the timing off. This happend to my machine recently and I had to take it to be expertly reset. I do not know if it can be done without an experts help or not. It wasn't a large bill to repair and my machine now runs like a top! Hope this helps you!
Posted on Oct 07, 2008
Not sewing
Suggest open bobbin case to see if loose thread has jammed it.
Apr 18, 2014 | Brother CS-8150 Computerized Sewing...
My sewing machine does not move at all
Is the bobbin winder on? If so, turn it off.
Otherwise, is there power to the machine?
And this happened while you were sewing? Cut the thread above the needle eye. Rock the handwheel back and forth firmly to try to cut the thread jam below the needle plate with the sewing hook. If that doesn't work, open the bobbin case area of the machine and try to pull the bobbin case out, cutting any threads you can see with a seam ripper. Still won't come? Take the needle out of the needle clamp and throw it away (it's bent!), and take the screws out of the needle plate (=throat plate) and take the needle plate off after cutting any threads you can reach under the fabric. Keep cutting and pulling out any thread you find, and eventually, you'll be able to turn the handwheel. Clean all the thread bits, lint, and junk out of the area under the needle plate, the bobbin and bobbin case, and the shuttle area... there will be directions in your manual on how to clean the machine, including the shuttle area. Reassemble. Put in a brand new needle, right way around and fully up in the needle clamp. Rethread from scratch.
Always hold the thread ends behind the presser foot for the first couple of stitches of each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551
Feb 05, 2014 | Brother LS-2125 Mechanical Sewing Machine
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Bobbin jaming up
Clean the bobbin area.
Thread the machine with the presser foot up - always,
Make sure the bobbin thread is feeding clockwise and through the guides on the bobbin case.
Lower the threaded needle down and back up while holding onto the thread end. This will pull the bobbin thread up. Hold onto both threads and pull under the presser foot and to the back of the sewing machine.
Hold on to the thread ends and lower the needle into the fabric, then press the foot pedal.
You may want to use a leader - a folded scrap of fabric that you sew to the edge of and then **** against the fabric you want to sew. Sew off the leader and onto the fabric and this will keep the thread from going down into the machine. You can have a few stitches between the two to make it easy to cut the leader away.
When you stop to adjust the fabric make sure the needle is down to anchor the fabric (turning corners, sewing a curve. etc).
The slightest movement of the fabric when the needle is up will sometimes cause a thread jam.
Mar 11, 2010 | Bernina Sewing Machines
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
How do you thread the bobbin
When you drop the bobbin into the case, there is a slot that the thread will slide in to. Gently continue pulling on it and it will feed itself through and come out at a small cut out. Then place the thread over the bobbin and rotate the handwheel to pick up the thread. If the bobbin case is not threaded properly, the threads will knot up and jam the machine. If you'll look closely at the bobbin case, you will see that there are actually two thin pieces of metal...the thread will actually slide between those two pieces.
Feb 28, 2009 | Elna Sewing Machines
Sewing Machines Logo
77 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
