Question about HP iPAQ HX4700 Pocket PC
Backlight Issue Does this sound like a hardware problem? My HX4700's backlight will not dim. The brightness is fixed at maximum. Moving the screen slider to the left (minimum) causes the screen to go dark. Any other position sets the brightness to max. I thought that flashing the latest bios might help but no. Any ideas?
    Master:
  • 450 Answers
Sounds like a hardware problem.
Posted on Sep 11, 2005
SOURCE:
Gateway Laptop screen goes dim.
Please connect it to external monitor. If it is not affected there. there, it could be an issue with backlight or inverter.- a hardware issue.
Jun 03, 2013 | Gateway Computers & Internet
The screen is very dim. The brightness is at 100% but it is still dark. What's wrong with the screen? LED backlight panel?
I think its a problem with the backlight, i recommend call lenovo support and have it service.
Dec 29, 2010 | Lenovo IdeaPad S10-3 Netbook
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 17, 2010 | RIM BlackBerry Pearl 8100
Whenever my Dell Precision M6300 is ever on maximum brightness, the backlight goes dark after 1-2 seconds. The screen is fully functional, but the backlight simply isn't working. I can get the backlight to...
guess there is an larger issue with your notebook.....
you need to get the backlite changed, if you have chanaged the lite then there is a compatibility issue with the screen and the invertor board that's behind the LCD screen.
or the system is not supplying the correct current to the backlite / invertor board
a HW tech guy may solve your issue
Nov 18, 2010 | Dell Precision M6300 Mobile Notebook
When i switch on my laptop I see the led lights on but the screen is blank. I do not even see the hp icon that shows up initially
Hello !
It is typically the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Aug 19, 2010 | Computers & Internet
Screen is very dim..can barely see it..bright adjust doesnt help.
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
May 17, 2009 | IBM ThinkPad T20 2647 Notebook
MacBook screen dims
first there could be many meanings of dims with a laptop screen one is backlight has turned off and it is difficult to see.  if that is the case use you brightness key to check if it is up, if it is more likely your inverter has gone up and in worse cases the screen. it may also start bright then change dim while loading
there is also the feature on mac to automatically dim the screen a little when unused for a set time.  to change this go to system preferences, go to energy saver, click show details, then move to options, and uncheck the the box that says "Automatically reduce the brightness of the display before display sleep".
i hope this is what you are talking about.
Mar 14, 2009 | Apple MacBook Mac Notebook
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Light is dimmed. Cannot make it brighter.
This happened to me, too, when I replaced the battery. Turns out one of the wires that affects the brightness came loose. I found the loose wire, touched it to a few places where I thought it should go, and one of them caused the screen to come on to full bright.
I was extremely nervous dealing with this - never soldered in such tight quarters before, but once I soldered it down, the problem was solved. I have other problems with my ique - like extremely limited battery life - but the brightness problem is solved.
Mar 02, 2008 | Garmin iQue 3600 GPS Receiver
HP iPAQ HX4700 Pocket PC Logo
387 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
