Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Stove won't unlock
I have a Kenmore 665 that won't unlock
  • hammerhead49 Oct 01, 2008
    oven door won't open is locked
Your range may be made by Whirlpool. I had the same problem with my Whirlpool oven and tried many remedies without success. I then pulled up on the door handle - the door raised a bit, and the lock released.
Posted on Oct 16, 2008
    Problem Solver:
  • 8 Answers
Some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Posted on Oct 11, 2008
I have a Kenmore oven model # 665.95024100 and used the logi-clean cycle and now the door will not open. This happened before when I used it and I called the repair service to fix it but I cannot remember...
Articles on the internet suggest not using the self cleaning feature of modern ovens, becuase fuses and other parts may easily burn out due to the high temperature.
Suggested methods to open a locked Kenmore oven at the artlcle at the link below:
http://homeguides.sfgate.com/clear-oven-lock-mechanism-kenmore-stove-71754.html
How to Clear the Oven Lock Mechanism on Kenmore Stove
Feb 26, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Tip
SEARS / KENMORE Range/Stove/Oven Manufacturers
SEARS/KENMORE
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built your Sears / Kenmore Unit. This can be helpful if looking for repair or replacement parts.
Your model is manufactured by the following if your units first digits starts with:
Amana 596
Caloric 174 / 960
D & M 587
Fedders 484
GE 362 / 363
Gibson 253
Jenn Air 829
Kelvinator 417 / 628 / 662
Litton 747
Maytag 925
Roper 103 / 155 / 647 / 835 / 911
Speed Queen 651
Tappan 79
Toshiba 562
WCI 790
Whirlpool 106 / 110 / 198 / 562 / 665
on Jun 10, 2011 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven door will not unlock, it is an older model and i have lost the manual. i tried to activate the self clean but i couldn't remember how all that ended up happening is that the door has locked...
Look around the console area for a button that says push to unlock. If it is there push the button in while unlocking the door. Some models may require that you also place the stove into self clean then canceling it out thus enabling you to unlock the door. Without a model number off stove tho it is all just guess worjk as all stoves are not the same.
Feb 28, 2010 | Kenmore Ovens
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 665 Error Code
You have a faulty control board its, a unerversal code pretty much. There web sites you can google it also. But it is a bad board.
Jul 14, 2008 | Whirlpool GBS307PDS Electric Single Oven
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
490 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
