Teac X1000R Reel to reel
Got it off of ebay for $300. Said in well kept condition. will not record but will erase tape, will fast forward but not fast reverse, tape wanders off pinch rollers in both directions. should we get money back or try to fix it? any idea how much to fix?
  • Sam Palermo
    Sam Palermo Mar 29, 2013
    On the money part- If the unit is not in its described condition you are entitled to a refund but a lot of my clients work out a deal with the seller in a partial refund. This seems to be the best equitable solution together with a proper service technician. I am way too busy- why do you think that is? Whatever you do with E bay do not wait. The solution to the problem needs to be take care of quickly. Shipping units back not only costs you money but leaves you nothng to show for the whole venture. I have even had customers send me their E bay purchases directly, then they get a perfect unit ready to go back.
  • Audio Player... Master
  • 1,267 Answers
The money issue is up to you. I would have a look at the heads and then take note of the cosmetic condition of the deck overall. The unit can be brought back to specs but no by just any shop or owner- it need to be worked on by a professional. I do them all the time. If you ask I will tell you where I am but generally I am not suppose to advertise. you most likely need a capstan belt and lub job.
Posted on Mar 29, 2013
  • 71 Answers
Hi ok, the system has relays now if this has been standing around for years doing nothing the relays will stick this could be the record problem , 0k the tape tension levers/ idle wheels either side that bob up and down control the tape speed regulator . this is the probable cause of why it wont rewind there is a control transistor tha has gone bad./ or open circuit . these machines are like cars in every way you must use them . now these units are very desirable teac made a mighty fine deck like all the company's. so do you get rid or fix i restore these decks all makes. i take it from the dollars logo you are in the states or did you buy it from the states. i am in the uk i am working on one of these at the moment. if it was me ,,,,,,,,,,,,,fix it they are a fab looker and they sound punchy and true analogue.you will get $600 to £1500 if in good condition if its silver more if you were in uk price to fix my price £190..00
Posted on Jan 19, 2009
  • Sam Palermo
    I am not sure a stuck relay is the issue in this deck- maybe older A series but mote likely the long slide switches that need Deoxit and exercise. Ebay often times is the cause of someone learning a hard lesson but if they persist in the right direction- then guys like me can restore the deck as good as can be. The X1000R was the best X series deck they produced. The X2000R was a cheaped out version with many flaws.
  • 1,512 Answers
Hi there. It will need a new pinch roller, and has a bias oscillator. problem. From memory, they use a module for the oscillator, and the pinch rollers are easy to get. Sorting out the bias may be the problematic part, and you will need to recalibrate the bias traps and controls if you want max performance from the unit once repaired. I would go about checking things like intermittent tape bias switch, and try wriggling the record play switch( internally) and see if you can get erase and rec back. Noisy intermittent switches can caused the symptoms you have.
If you are able to, I would be seeking a refund. If not, then repairs are feasible. Let me know where you are and I can help you find a repair guy. Cheers
regards
robotek
Posted on Sep 07, 2008
  • Sam Palermo
    If the deck erases there is nothing wrong with the oscillator but you may be correct in the slide switches that move for reverse operation. Bias traps are ONLY adjusted when either someone plays with them or the heads are changed. This comes from a Teac Technician and the service manual.
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
When play is punched in either direction it want move,not even in
yes, one nice overhaul will fix..(this can be done by you if you are daring...when u open take apart you will find a metal strip like band..I had used a bandaid for brakes the gauze side) you need new brakes (just like a car it is run down) on the reels in order for it slow & stop when it suppose to...or you can search and find a good old fashion repairman..(sorry I dont know of none)...for dragging, before playing all open reels fast fwd to one end then rewind it back to the beginning now hold the blank reel with that little bit catch tape try to tighten full side tape by going slightly going the other way not trying to stretch nor pop the tape.....now press play
Aug 07, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Jan 23, 2009 | Audio Players & Recorders
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Mar 25, 2008 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
346 people viewed this question
 Grubhead
Grubhead
