Question about Sony Walkman D-NF400 Personal CD Player
What does Hold mean? Sony D-NF400
If I open my walkman, a flashing 'HOLD' would appear
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
D-NF400You have locked the controls with the hold option:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 29, 2008
Sony walkman NZ-E353 was working fine both alone and attached too a docking station. Next day it won't come on and keeps flashing "HOLD" before turing off.Battery is fully charged. Please...
I'm sorry that the Walkman Player is not turning ON normally and displaying "HOLD" message. The "HOLD" message indicates that the Walkman player is set to HOLD mode by sliding the HOLD button on the right side. Please make sure that the HOLD switch is not activated.
If the issue persists after moving it from HOLD position, please reset the Walkman player by pressing the reset button using a sharp pointed object. The reset button is located on the rear of the unit.
Thanks for understanding. Please let me know if you require any clarification.
Jul 31, 2011 | Sony NWZ-E353 MP3 Player
My SONY WALKMAN NWZ-S545 does not start up. It stucks in "Every Moment Has its Music" loading screen. I accidentally deleted the ".trash" folder in my Linux Ubuntu virtual machine....
I do not know if I had the same problem, but similar. As far as I know, I did not delete the trash folder. However, it would not start. The "Every Moment.." screen would go on, then shut off.When I hooked it via USB to the PC, windows 7, the computer did not recognize it, the icons for it did not appear. So I tried turning it on rapidly, rapidly pressing any button, it flashed on continuously for a shorter period. Then I switched the left-hand buttons down, off ear-phone and off hold. Plugged i9t in again via USB and it went on. It is working. I tried taking it off "hold" before to no avail. Battery was just about dead. So I think what might have happened: when I tried to take it off hold before, the battery was too weak. Because I just kept trying to turn it on while taking it off hold, I caught that grace second when the battery sent a second of power. Of course, this theory of why it now works only holds water if in fact the PC will not recognize the walkman if it is on hold. Another theory is the PC can only detect the walkman if there's a little battery power sending signal to the PC. What ever,now it is working.
Dec 29, 2010 | Computers & Internet
Says there was a format error has music on it but won't play
The Format Error will get displayed in the Walkman Player when the unit is Formatted using the format utility in windows explorer or with other internal malfunction.
To resolve the issue, try resetting and then perform the Formatting the In-built Memory option in the Walkman player.
To reset the Walkman, press the RESET button near the USB Jack for more than 1 second with a thin instrument such as a paper clip.
If the issue persists, FORMAT the Walkman.
To FORMAT the Walkman, press and hold the MENU button in Stop mode until the SEARCH Menu appears.
Then, use the control Jog to select Advanced Menu and press > VOL to confirm.
Again, use the control jog to select FORMAT and press > VOL to confirm.
Now, select OK and press > VOL to confirm.
Formatting appears and starts formatting the Walkman.
When the Formatting complete, COMPLETE appears.
Press the > VOL button to return back to the playback screen.
After Formatting, download the MP3 File Manager Application to transfer the songs from the Computer to the Walkman.
This will resolve the issue.
Thanks for using FixYa.
Dec 08, 2010 | Sony Walkman Bean NW-E307 MP3 Player
On hold... cancel Hold function to activate
This is not an issue with the Walkman player. You can resolve this by sliding the HOLD switch located at the side panel of the Walkman Player (Model specific).
HOLD switch is used to protect the Player against accidental operation. By sliding the HOLD switch in the direction of the ">", all the buttons are disabled. If you slide the HOLD switch to the opposite direction, the HOLD function is released.
Jun 26, 2010 | Sony NWZ-E438F Digital Media Player
Only show the Walkman Logo
press and hold "volume -" button while connecting to pc...then it must be detected
Sep 01, 2009 | Sony Walkman NWZ-B135 MP3 Player
Files cannot be deleted or moved to the device because "the device has either stopped responding or has been disconnected".It is a Sony NWZ E436F.
Reset the Walkman by pressing and holding the Reset button for 30 seconds. Then, try transferring or deleting any files from it. Furthermore, if the issue persists then try formatting the internal flash memory.
Follow the steps given below to format the internal flash memory of the Walkman:
Press and hold the Back/Home button in the Pause mode until the Home menu appears.
Press the up/down/left/right button to select Settings, and then press the >|| button to confirm.
Press the up/down/left/right button to select "Common Settings," and then press the >|| button to confirm.
The list of "Common Settings" options appears.
Press the up/down/left/right button to select "Format" and then press the >|| button to confirm.
"All data including songs will be deleted. Proceed?" message will appear.
Press the up/down button to select "Yes," and then press the >|| button to confirm.
"All data will be deleted. Proceed?" message will appear.
While the memory is being formatted, an animated display appears. When initialization finishes, "Memory formatted." message appears.
Aug 24, 2009 | Sony NWZ-E436F MP3 Player
Sony Walkman D-NF400 Personal CD Player Logo
1,747 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
