Question about Gaggenau Ovens
Gaggenau Model EB 378 610 Electric Oven
Oven will not heat unless timer is employed...then, heating is irregular; sometimes staying on high, and other times not heating at all. We removed the sideplate and disconnected the temperature probe, finding a burn mark on the box to which it was connected. Upon opening that box, we found a thin metal band burned through. Then we bypassed the box altogether, taping together both wires that went to it, thinking that perhaps we'd get heat; but that didn't happen. Can you shed any light on what might be the problem?
Thanks.....Michael
  • jvent Aug 29, 2008
    please can y7ou help
  • 10 Answers
SOURCE: Oven keeps switching the fuse box off
you must get someone who understands electrical problems to look at it as this light is at full mains voltage, if the wires are burned then they must be replaced with ones that are silicon covered because of the heat and if a connector is used then this must be made of a ceramic material again because of the heat
Posted on Aug 03, 2008
  • 417 Answers
SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Posted on Nov 30, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
ABKSeeker
  • 69 Answers
SOURCE: changing from C to F temperature on Gaggenau EB
your oven has no ability to change from celcius to fahrenheit here is the link to the manual:
http://www.gaggenau.com/AP_en/products/product-detail.do?contentId=cc4fb38a-ea89-4593-a268-95ea093f9d3f
there might be a secret mode but only the manufacturer might know that.
all dealers are in other countries.
Sorry I could not resolve this issue for you.
Posted on Feb 15, 2010
  • 457 Answers
SOURCE: need a clock/control module for a 24
You can go to thermador .com Bosch,thermador gaggenau all same company.
Posted on Feb 26, 2010
Tip
Bosch HBN13M250B/01 not heating or fan is not turning, common faults.
For all Free Bosch appliance repair videos visit our VIDEOTUTORIALS
A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob.
With a little time, though and our FREE fan oven element video itshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on
1, If the Bosch fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
To gain access to the Bosch element you will haveto remove the back plate from inside the oven. Once removed you will see the Boschfan and element, if you look closely at theBosch element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your Bosch fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your Bosch oven thermostat
4, A quite common and easily overlooked answer isif your oven is not working atall ie: no heat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
on Jan 13, 2010 | Bosch HBL 5052 Electric Double Oven
Oven does not stay on
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Jun 14, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore oven does not heat evenly
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Feb 10, 2014 | Kenmore Ovens
Oven off and on
The reason for my free advice is GOD is good!
Aug 19, 2012 | Whirlpool Ovens
Model 444445410 pven will not stay lit
Aug 15, 2011 | Belling Ovens
How do I set the time of day on a Gaggenau Wall Oven, EB 985611?
How do I set the time of day on a Gaggenau Wall Oven, EB 276-610?
Mar 08, 2011 | Gaggenau EB984 Electric Single Oven
The electrical mains switch was turned off. When I turned the oven back from the mains , the oven turns on but does not generate heat. I think it is something small do with my settings. Can u help....
If it has a timer, then when the power was on again, it probably reset to auto, you need to reset it to manual cooking
Refer to your instruction book if you have one.
Otherwise it is a question of pressing 2 or more buttons at the same time on the timer to reset it to manual
Feb 12, 2011 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau Wall Convection Oven EB 270 installation instrutions and electrical hook up.
http://www.gaggenau.com/US_en/service.do
you can download installations and user manuals from this site. You'd probably be better putting the full Enr (model) number in the search.
Click where it says 'All manuals available for download' this will open a window where you type in the model. You then get a long list of manual, I presume you want it in english, so pick the one that had EN in the first column and II (installation instructions) in the next column.
Hope the is what you're looking for, all the best.
Jul 05, 2010 | Gaggenau EB 270/271 Electric Single Oven
How to take the door off a gaggenau eb 290 oven
gaggenau oven EB 378-6 door won't close completely It pops back open 2 inches.
Apr 23, 2010 | Gaggenau EB290 Electric Single Oven
Ovens Logo
618 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
