My LXI TV won't allow me to get any channels above 13 after doing the auto scan for channels. I am using DirectTV.
The only way to fix the problem is to hook your TV to a standard cable hookup and go through the "auto memo" scan process. The auto scan progarm then automatically sets itself to the CATV mode, rather than the standard mode, so channels above 13 can be received after disconnecting and reconnecting to a DirectTV, satellite antenna.
Posted on Aug 30, 2008
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
I have connected the tv to cableand I can only recieve channels 2,4,5,9 & 13. How do I set up the tv to receive the remainder of the channels? Thank you
do a channle auto scan, you need to select CATV in order to scan for cable channels. after the scanning process, all the channels you can get should be on your set.
Mar 19, 2011 | Sharp Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
The TV cannot locate TV channel source, which is DirectTV box.
use DirectTV box video to tv video1 input
use indoor or outdoor antenna to tv ant input
setup tv cable to antenna
scan channe.....watch tv...
Nov 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have a LXI series 13''tv,no manual-can't program channels
in menu switch the language to english, then find the channel setup feture under that there should be an auto search option run that and it should setup ypur channels
Sep 10, 2009 | Televison & Video
In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Mar 20, 2009 | Zenith Z32X31D 32" TV
Lxi television manual
I have a 52' LXI that was given to me, I am having trouble programming the channels with a cable output. The TV starts at Channel 7 but those channels before it does not come in with my cable output or ANT out put. How do I get those channels to come in
Nov 04, 2007 | Televison & Video
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
