Question about Black & Decker String Trimmer Cordless 12" 18V
12 volt grass trimmer/string breaking
When i use the trimmer for a short time the string breaks then I have to take it all apart to refeed it. What a pain. Is there anything that can be done so it doesn't keep breaking?
  • benib Sep 27, 2008
    Not auto-feed & have to keep doing manually, tut.
    Problem Solver:
  • 12 Answers
Just a reminder, do not use cordless string trimmer as heavy work.
Posted on Aug 30, 2008
My string keeps breaking causing me to refeed the string thru the eyelet.
Are you using thick enough cord for the machine?
Are the eyelets worn and have sharp edges.?
Is it being threaded correctly?
May 22, 2016 | Worx 24-volt Cordless Electric Lithium-ion...
Black&decker GH 1000 trimmer. The line breaks when spool is full
Try using a thicker line when using the thinner line it is good only for grass if you should hit fence or concrete it will eat it up and you will be pulling it out every 5 minites or less.
Jul 06, 2010 | Black & Decker String Trimmer Cordless 12"...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I have a Black and Decker Grass Hog trimmer and I can't get it
There is only a couple of reasons that I can think of that would cause this
1. The string is wound the wrong direction; it should be wound clockwise on the spool. (This is my bet.)
2. Or maybe, the string is too small for your particular trimmer, but this is very doubtful.
Jim
Jun 18, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
SPOOL
You have the string wound the wrong way. Wind in the other direction.
Jim
Jun 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black and decker 110 volt grasshog
The last time I used the weed wacker it kept stopping-almost like a short. The battery is fully charged and has a lot of power when working. Would the problem be in the handle and can that be taken apart to see if there is a loose wire?
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
258 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
