Question about Minolta Office Equipment & Supplies
Minolta 2500 Color Laser: Vertical white line being produced on color prints
    Master:
  • 848 Answers
There is some problem with print head nozzles. Lines across a printed image are a tell-tale sign of clogged print head nozzles...
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Either the printer is nor serviced or the cartridge is near to end.or the final thing the drum of the cartridges are faulty,and need to be replaced.these are the only three possibilities.so please do not worry these are the common problem faced by every laser printer user.and it can be checked and cleared .by checking these possibilities.your printer is perfectly ok.
pls do rate the solution
thanks.
regards.
fixya expert team
  • tech expert12 Aug 29, 2008
    print head nozzlels are in inkjet printers .this is lase printer and it does not contain any print nozzle.i am one same in front of me.and whenever face this problem .get my cartridges refilled or service the printer myself.and the problem is solved.thanks.
    try to remember how much printouts you have given till now.if too much then the cartridge powder is at its end.refilling is necessary.if the printout that comes out looks very dusty.or the printer is having too much dust on its inner area then servicing is required.cartridges are full ,,printer is clean.and stii the problem.then its faulty drum in the tonner cartridges.
  • 6,487 Answers
The printout might show visible white line. This problem occurs when the toner gets clogged. Shaking the toner cartridge might remove the clog; otherwise the cartridge will have to be replaced.
Hope that helps..........
  • Minolta Master
  • 1,879 Answers
Happens to all modes ? perform cleaning, take the toners & photoconductor unit + clean + gently tip side to side then put it all back.
    Genius:
  • 1,269 Answers
Try to turn off the printer for about 5 mins, unplug the power, unplug the USB cable. Then plug all the cables back in, turn on printer. Check if that fixes it. Otherwise, you need to update the driver of your printer.
Konica Minolta c451 is showing white linen the printed work
for black and white??? or a color????? Means you might have something blocking the LASER for that color. print out a test chart for each color which one has the white line?
Jun 22, 2016 | Konica Minolta Office Equipment & Supplies
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
http://www.laserquipt.com/support/idx/26/452/article/Toner-Smearing-Issues.html
Mar 25, 2010 | Brother MFC-9440CN Laser Printer
White vertical lines down printed documents...
hello
you have to check the fuser film, it may be not good
regerds and dont forget to rate mt answer
Feb 19, 2010 | Konica Minolta PagePro 1400W Laser Printer
Printer leaves two white lines when it prints.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. syberspirit@yahoo.com
Nov 06, 2009 | Konica Minolta magicolor 2430 DL Laser...
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Magicolor 2430 DL vertical lines.
pleas take a closer look at the pc drum and transfer belt, if there are also stripes then you find a problem, stripes on pc drum means new pc drum and on TBU there is possible to clean the cleaning unit but not in every case. if cleaning doesnt help new TBU
Sep 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
32 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
