Question about Amana Kitchen Ranges
Amana range model ARG7102W has error code FFF
What does error code FFF refer to.
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
aborcass
  • 2651 Answers
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Posted on Mar 18, 2009
  • 10865 Answers
SOURCE: We have an Amana Range/Oven
Hello. Your problem is this:
when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results and the symptoms you have described.
if you want to replace the bake element yourself you can or if you are going to have it repaired call around and get a few estimates. good luck with it.
Posted on Aug 20, 2009
delpolito54
  • 44 Answers
SOURCE: amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Posted on Sep 01, 2009
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Oven doesn't work. Panel shows "FFF"
FFF code - Control error, failed EEPROM
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).
Replace the oven control board (also called clock or ERC).
Hope this helps.
Jun 27, 2011 | Kitchen Ranges
Amana Model ARG7102W ERROR F02
Hello, Thank You for using FixYa. I will be helping you today.It means runaway temperature. Test oven sensor for 1100ohms if out by more than ten ohms replace sensor.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kitchen Ranges
Display on oven reads FFF. the oven no longer works but the stove top does
Try unplugging the range for about 15 minutes. The ERC (electronic Range Control) may reset itself. If you still have the fff code on the control it will need to be changed out.
Apr 03, 2010 | Amana RanARG7302 Gas Kitchen Range
When burners are turned on Code F1 shows up and starts beeping
Hello, an F1 error code for an Amana refers to a failed watchdog circuit or ERC (Electronic range control) and need to be replaced. This can be located inside the control panel and is normally accessed from the back of the range. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Amana AOCS3040 Electric Single Oven
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
Model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Nov 12, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchen Ranges Logo
218 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
