Question about Danby (DAR604BLS) Refrigerator
Frost free fridge making gurgleing sound
Sseveral times a day & night a strange gurgleing sound coming from the back of fridge. It is a new sound, We have had the fridge for 3 years. Is this a problem to worry about?
    Scholar:
  • 132 Answers
Mine does the same its sort of like a food digestion sound a reliable fridge mechanic that i have used for over 15 years told me this sound is normal and if it stopped then it would be a problem so no dont worry its fine glenn.....
Posted on Nov 22, 2008
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Fridge runs 5 min turns off for 15 all the time
most thermostats are standard and you may find one at your local recycling centre.
Dec 19, 2014 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Zanussi frost free fridge freezer leaking
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Refrigerators
Frost free fridge has frost and refrigerator is not cool enough
hi there, sounds like you fridge is short of gas, you will need to take it in to be repaired, and it wont be cheap.
Sep 09, 2008 | Refrigerators
Electrolux E23CS75DSS Noise
Hi Andy, I have had luck insulating the cap tube coming off the heat exchanger, going into the evaporator. If the repair man can wrap some mastic around the area where the cap goes into the evap, this may quiet it down enough. This is common on some models. Some people are more in tune to it than others. Give that a try. Catriver.
Jun 16, 2007 | Electrolux E23CS75DSS Stainless Steel
Danby (DAR604BLS) Refrigerator Logo
760 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Steven Clarke
Steven Clarke
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
