Question about Sharp Microwave Ovens
Microwave, convection R930AK turntable will not turn and microwave will not cook. inside light works
  • Sharp Master
  • 9,098 Answers
That would be a defective secondary (lower) door switch or possibly the door switch mount is loose or misaligned.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Posted on Sep 01, 2008
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Just like others, the microwave component does not work. Convection works just fine. Before microwave quit, it appeared to have something to do with the door(?) I would put a napkin b/w door and by...
If the inside light, fan and turntable come on when you try to cook, but it does not heat, this is probably a bad primary interlock (top door switch) or possibly that switch's mount is bad.
See this file on safety, and this file on door switches.
We have the full service / installation manual for this unit, and have uploaded it here to help you.
If the inside light, fan and turntable do not come on when you try to cook, the 20A fuse is probably bad or loose in its holder.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Advantium SCA2000B Microwave Oven
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Mar 25, 2010 | Sharp R-930AK Convection/Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
