SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
