Question about Breadman TR875 Bread Maker
Loud banging during kneading
After two years, my machine has developed a loud banging sound during kneading. Sometimes it happens once with each revolution of the paddle, sometimes less. The noise is loud enough so I've quit running the machine at night--even half a house away it will wake me up. Sounds like the gearing is slipping, causing a jump before connecting again. Any suggestions?
  • dirkdev Aug 29, 2008
    I'm looking for help with a bread machine; the expert I was referred to referred me in turn to another site for repair advice, but one only dealing with major appliances.
    Yes, the answer was helpful, though not the one I was hoping for! Thank you.
  • 6,487 Answers
The belt was loose, and it often slipped out of the notches during the kneading cycle and the result was a loud banging noise , you can try checking that belt if you can open the unit or just have it repair or replace...
Good luck.........
Posted on Aug 29, 2008
    President:
  • 1,263 Answers
Most like ly that is the case a gear has ground down teeth and spins until it catches which creates the banging noise. unfortunately it would cost more to repair it than to replace it. most aplliance repair places might not even have the parts for it. so your best bet is just to get a new one. I'm sure this is not the answer you were looking for but it's the right one good luck. please rate this solution. thanks
  • 3,037 Answers
Usually with products like this, one gear will be a plastic instead of metal which under too much stress will shear. Basically to narrow down the problem, you will need to open up the machine and find the part that is worn down considerably and then we can get you to the manufacturer or another retailer that can get you the replacement part
    Master:
  • 521 Answers
You are right.for further help check this link.
www.repairclinic.com
  • tech expert12 Aug 29, 2008
    you will have to replace the kneading paddels for sure to solve this problem.as simple oiling may work temprory but for permanent solution replacing the kneading paddels is necessary.remaining everything is perfect in the bread maker.
    for any thing else let me know.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
GE front load is making loud banging noise during spin, any ideas how to fix?
Sounds like what happens in a top load when the load is "out of balance". I suppose it's less likely to occur with front load. Test with a "light" load. Is the washing action a reversing action? If so there may be a transmission problem.
Apr 11, 2015 | GE Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
I have a toastmaster Bread Box bread machine...I am making French bread...the banging noise was so loud I stopped it fearing the machine was broken...is it ? If not should I continue the kneading/baking...
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Nov 08, 2010 | Toastmaster 1183N Bread Maker
Rotating shaft will not rotate - during the kneading process nothing happens
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Aug 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Banging during the wash and spin cycle
sounds like drum is out of balanced call repairman they can rebalance drum this needs to be done ,once a year.
Dec 16, 2009 | Frigidaire GLTF530DS Front Load Washer
Loud bang during dryer rotation. front loaded dryer. dryer is six years old. bang is with evry rotation of drum.
not nkowing what brand, I would guess its a maytag or one of their brands. It sounds like a screw that mounts one of the paddles inside the drum has backed out and is now poking out the out side of the drum hitting the cabnet as it goes around. Un plug it , pop the top open , rotate the drum clock wise by hand slowly to see if a screw is standing up on drum.
If its a whirpool dryer with the lint filter inside the door, the top cabnet is dented down, hitting the drum.
someone sat on the top, bent it down.
Nov 21, 2009 | Washing Machines
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Breadman TR875 Bread Maker Logo
729 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
