Question about GE Profile PSI23NCR Side by Side Refrigerator
Side by side humming
Side by side seems to be working fine, but has started humming. somedays not at all, others for hours at a time.
  • markinky Sep 10, 2008
    A few weeks ago, I learned on this site that the VERY HOT door seals were due to the blower fan not turning. I flicked the fan with a screwdriver and it has run ever since -- and very quietly.
    Yesterday, it started a moderately loud humming noise. I haven't pulled it out from the wall to investigate (but at least the condensor blower fan is still running). I wonder if it could be related to the ice maker which isn't making ice?
  • 163 Answers
That is related to the ice maker everything has to be functioning properly for it to make ice
Posted on Mar 07, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Pontiac grand am
The engine in this car is controlled by an on board computer, when a problem like this occurs in most cases the computer stores a fault code for the problem, you need to do a fault code test by using the diagnostic connector under the dash in front of the driver, If you click this LINK it will show you how to read the codes without a scanner.
Feb 14, 2012 | 1996 Pontiac Grand Am
1996 vw jetta problem with the headlights. The daytime running lights work fine the high beams work fine, but when you turn on the lights from the switch the driver side headlight turns off. I've checked...
I don't have a wiring diagram ,but on most cars I would say your low beam bulb is bad. Try swapping sides to see if the problem goes with it, or just replace the bulb. You can always keep the new one until needed someday... shadetree mech by necessity.
Dec 09, 2010 | 1996 Volkswagen Jetta
Frigidaire side by side making a vibrating/humming sort of sound
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Apr 18, 2017 | Frigidaire FRS26H5AS Side by Side...
Car starts but turns off try starting car second time it will start with a little gas will run fine. it does this every time when starting car. was told that fuel pressure is low. car accelerates with out...
i would somehow either test the fuel pump and filter and replace the one that is not working, or replace them both. to test the filter you can try to take the filter off and blow through it. if no air comes out the other side, its clogged. for the pump, turn your key until it stops before the engine starts and listen carefully for a hum from by the gas tank. the hum is the fuel pump turnig on; if their is no hum, your fuel pump needs to be replaced.
Jul 19, 2009 | 1996 Pontiac Grand Am
Oil leaking out from under freezer side.
That oil is probably compressor oil. If the compressor leaks, you need a new fridge. Sometimes they only leak when they're charged up. That would explain the other symptoms.
Oct 16, 2017 | Frigidaire FRS26H5AS Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Profile PSI23NCR Side by Side Refrigerator Logo
109 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
