Question about Olympus DS-30 Digital Voice Recorder
DS 30 recorders support
We have purchased 8 DS 30 recorders at different times in the past 16 months, only 1 works with an adapter, the others are only working with batteries please give me some recommendations.
  • 1 more comment
  • jmo12345 Oct 06, 2008
    We have been using both source for months, we use both in hte ven there is a power shortage or a surge.
    Are we suggesting that this is something that happens over time.
    Thx
    jmo12345
  • jmo12345 Oct 07, 2008
    All your help is much appreciated, we record away from the office and download at the end of the day direct to our server.
    We have always use rechargable batteries as the back up in the event of a power surge and power temporary interruption.
    Again, thanks for all your help.
    jmo12345
  • Tim Babcock
    Tim Babcock May 11, 2010
    I've only seen these run off batteries. Do they allow the USB interface to act as a power supply as well?
    Does the AC adaptor allow for batteries to be installed as well?
  • 2,794 Answers
I think the units are designed for rechargeable batteries if you leave the ac adaptor in the recorder at the same time. You can probably charge it up through the usb cable as well.
Posted on Oct 06, 2008
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
The manual states that the recorder may not work with the batteries in and ac adapter connected. if you connect to the usb do not have the ac adapter plugged in. you dont even need batteries in the recorder to connect to the computer
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
Recognition of recorder
Does the computer recognize the Olympus DS-30 being connected to it at all? If not, do you happen to have another USB cable that you could try using? Either way, you should try connecting it to a different USB port on your computer, as you might have happened to connect it to one that doesn't work.
Jan 06, 2008 | Olympus DS-30 Digital Voice Recorder
COMCAST has just completed digital migration in my town, in January of 2010. They issued free DTA adapters or free set top boxes. Each choice has a new remote that would bring in all the COMCAST...
The latter part of your comments look familiar. Virgin Net did a similar thing and when the transmitters went to digital, all analogue recorders were rendered useless. All they could do is record the channel you are watching!
Sign of the times I think!
Jan 13, 2011 | Televison & Video
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Olympus DS 30 Handheld Digital Voice Recorder: screen problem
is there a label on the screen... when you turn the device off.. does the display turn off ...
the recorder creates files whenever you hit the stop button... the ds-2400 will not make a new file unless you press the new button... this recorder does not
Jul 07, 2008 | Olympus DS-30 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Nintendo ds games not working
With three boys we frequently have this problem and we found that rubbing the pins clean with a Qtip dipped in rubbing alcohol and then wait for it to be mostly dry before re-inserting. Some times we have to do this 2 times  - good luck!
Nov 30, 2007 | Nintendo DS Console
Recorder came without USB cable and Manual
DS-30 manual you can find it here
You can use any standard USB cable for the DS-30 any radio shack store carry it,
Oct 20, 2007 | Olympus DS-30 Digital Voice Recorder
Olympus DS-30 Digital Voice Recorder Logo
53 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
