Question about Motorola Mobility RAZR V3m Cellular Phone
I replaced the outer and inner LCD display screens which are connected to each other. the outer display lights up but is upside down and is fixed on just saying verizon nothing else. Inner display is
Outer display upside down and only shows verizon name nothing else
    Problem Solver:
  • 19 Answers
Sounds like software issue not display, master reset!
Posted on Sep 20, 2008
How can i replace an LCD Screen Display a verizon LG extravert VN271?
Here's a video showing you how to take the phone apart: How to take apart lg phone It's not very professional, but you can use it anyway. Here's a replacement outer screen: Original OEM Verizon LG Extravert VN271 Outer Glass Front Digitizer... Lastly, here is the inner screen: Verizon LG Extravert VN271 LCD Display Screen Replacement Part Parts... Good luck!
Jun 20, 2014 | LG Cell Phones
Will replacing the inner screen of my lcd tv fix the damage done by wii remote? outer screen is not damaged
You need a replacement panel. Most people will not even bother as the cost of a replacement panel could easily exceed the value of the TV
Sep 03, 2012 | Samsung LN40A550 LCD TV
The Outer screen is blank (drak)
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
May 10, 2010 | Nokia E90 Smartphone
Replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Conair Health & Beauty
Hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
Nov 20, 2008 | Hyundai L91A 19" LCD Monitor
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Display Problem
check the flex ribbon wire that connected to LCD, or maybe you have damage flex ribbon wire you have to replace a New one FLEX. enjoy your phone!!!
Sep 12, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
200 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
