Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
Projector InFocus LP540
I need your support in order to find a lamp for the projector InFocus LP540. Somebody helpme.
I can repair my self
Thanks
Jenizeth
    Scholar:
  • 167 Answers
I agree!
However you can still find good deals on eBay occasionally...
The lamp is a SP-LAMP-017 the same lamp is used in the LP640 as well as the ASK Proxima C160 and C180
Do not buy a Chinese "Replacement for" as these are usually unreliable at best.
Posted on Dec 11, 2009
Ask the guys at GOTABULB.com Through e-bay they are very good in america
Posted on Aug 30, 2008
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
It wont turn on? i press the power button and nothing happens. Thats it.
I think that you projector lamp is broken, check all the contacts of the cables, if they are ok than the only thing (that i know of) that could be wrong is projector lamp
It's quite expensive :(
Oct 02, 2010 | InFocus LP540 LCD Projector
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 Projector Lamp Does Not come on> it has an error message; "Lamp didn't Strike". Does that mean the Lamp/Bulb is bad?
It's most likely the lamp is bad or the part that starts the lamp called a ballast is bad. The LP540 model has an issue with the ballast burning out. The ballast is a part that starts or strikes the lamp. The only sure way to test is to try starting it with a known good lamp.
You can check for signs of a bad lamp. Think about how long you've had your projector & estimate the total hours on your lamp. If it's over 500 it very well could be the lamp as they fail at any time. Remove the lamp cover door & pull out the lamp to visually inspect it. Look in good light & use a magnifier if available too check for any cracks or chips in the small bulb & look to see if the round part of the small bulb is covered with a lot of white or if it's not round anymore. If it's very white it means it has a lot of hours on it. If there's any loose glass inside (check by turning the lamp cage in different directions) then the lamp is bad. If it's nice & clear or has only a small white spot it's probably a good lamp.
I repair almost all Infocus models if you need a quote.
Thanks & good luck,
Jim
Jan 13, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540
I haven't serviced an infocus projector before, But I have seen 3 or 4 Red cutting out display simptoms on projectors caused by bent or pushed in gold pins on the VGA leads. (it always seems to be red!) I won't comment on insides but do check this basic tip before delving in too deep. Good Luck
Sep 24, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540 --- display
It sounds like you may be feeding it with an HDMI source using an HDMI to M1-D adapter...
If this is the case, make sure the source in not set to a resolution higher than 720p.
However I really need more information to offer a definitive solution.
Take Care!
Sep 17, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
204 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
