Take apart AOC LM929
How do you take apart a LM(@( Monitor. There are no screws.
2 Suggested Answers
SOURCE: AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Posted on Feb 15, 2010
I have a AOC L520 MONITOR and the touch screen doesnot work.Were I can found the software?
Here, from the manufacturer's website.
ftp://ftp.aoc-europe.com/Drivers/LCD-monitors/LM520&LM520A.zip
Rulan
Jun 16, 2011 | AOC LM 520 15" LCD Monitor
How do i take the back off of my AOC 17" LCD Monitor
Ik think you should remove some screws. after that, most of the times there are clips that holds the two parts together. The best you can do, is squeeze a guitar pic or so betweer the panels, and twist the guitar pick. That will do the job.
I said a guitra pick, but it can be anything. As long as it is flat and thin.
Apr 22, 2010 | AOC LM-727 17" LCD Monitor
When I turn on my MAc G4 my 19'' AOC Monitor turns on but then says ''No signal going to sleep''
When you are turn on the power supply going through cable is remain good but somewhere it is found in monitor that cable is broken,then it might be problem of monitor.
Oct 31, 2009 | AOC LM929 (Black) 19" LCD Monitor
Osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  3. Click CONTROL PANEL.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Aug 12, 2009 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
AOC lm929 monitor
piece aside.
Aug 29, 2008 | Computers & Internet
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
Power
check the power pack to see if it has the required output voltage, usually 12-15 volts. solidstate power packs are prone to failure. The LCD screens require between 2 and 4 amps to power them. A strain on some power packs. Gary(Honkity Hank)
Sep 18, 2007 | AOC LM929 (Black) 19" LCD Monitor
Monitor picture goes extremely dark
sounds like the backlight is defective. You can probably get a new backlight online if your comfortable taking apart sensitive electronic equipment BUT you must be very very carefull and handle the lcd with care as you can easyly damage it. Oh one more thing the power supply may also be defective for the backlight. I would contact the manufacture to see about the repair or replacement parts as they should be listed in your operators manual. Good Luck
Apr 22, 2006 | AOC LM-727 17" LCD Monitor
Computers & Internet Logo
240 people viewed this question
David Payne
David Payne
