Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
Unable to access my disk with any operating system
I m unable to access my disk with any operating system, but this disk show in bios only,
I tried with the bootable CD of partation magic then its show the disk with two partation NTFS but when i try to access the hard disk its hang, and
whn i try to with fdisk its show 2 partation NTFS, and i try to create new partation its hang,
so finally i m unable to create partation on my disk and unable to access,
some time partation magic show a error with cross the cyclinder error
  • 13,433 Answers
Hey,
Seems you got a broken down drive, you can try it on another computer to see if the issue persits or take it to a computer repair shop to get it tested, no not wallmart, some real computer repair place
Thanks,
Ekse
Posted on Aug 29, 2008
I want to partition my hard disk and install windows Xp on the new partition
if u have already installed operating system then just use norton partation magic u can download form www.downloadha.com and then boot form xp cd and install other partaton also u can get xp sp3 form same site. burn as boot able cd.
Sep 22, 2010 | Computers & Internet
Check media no operating system found
This means that your pc didn't found operating system in the drives that tried to boot from. To make it simpler:
1. Your hard disk isn't accesible by the system (solution: check the bios settings)
2. You haven't installed (or it's disconnected) a hard disk (solution: install one or check the connections)
3. You're trying to boot with a non bootable cd (solution: use a bootable one)
4. Your cd/dvd rom is not accessed by the system (solution: check the bios settings)
There are some more minnor cases but I don't have enough details for your case and I don't want to make you in panic.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 03, 2010 | IBM NetVista PC Desktop
I have an image file ''win 7'' downloadedit, i want to burn it in DVD bootable to install in my pc, i have tried with nero, magic iso, imgburn but when i restart my pc, it doesn't start from cd and i can...
Ignoring the suspicion that any "downloaded" image of Windows 7 probably is a "bootleg" copy of copyrighted software ......................
Restart your computer, and immediately press DEL to enter BIOS SETUP mode.
Reconfigure your "boot devices" to make the CD/DVD reader the *FIRST* bootable device.
Save the updated configuration, and reboot with the disk inserted into the reader.
Or, try the disk on another computer.
Jan 04, 2010 | Microsoft Windows Vista Home Premium with...
Have an Acer 5315. Used the system's restore
Disconnect any external devices, plug in your power to a A/C outlet, re-install the restoration disk and start over.
Check your BIOS again to make sure the CD is the first boot drive. You may not be saving the BIOS change or the restore disk may not be bootable.
You can check the restore disk on any PC or laptop.
Also you may have a restoration partation on the hard disk. Get you docs. and check.
Sep 20, 2009 | Acer Aspire 5315 Notebook
My computer wont start...it keeps saying missing NTLDR?...what do i do?
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Sep 20, 2009 | Computers & Internet
Windows98 saftwer insletion
Windows 98 software installion?
if your you should have the bootable CD or floppy disk for win98.
when you boot the computer then you have to choose the option that suppoet with CD ROM. BE sure that your harddisk must'n be in NTFS file system. if it in NTFS then it is better to use winxp or you can delete the partation the.
ok try this .
pls infor me what kinds of software do you want to install.
ok byee
May 06, 2009 | Microsoft Windows 98 for PC
I try to install an operating system to my machine but it is unable to see the bootable compact disk.
Please check the CD whether the cd is a bootable one or not in any other machine. If it is bootable and is not running on your system the problem is with your drive. Please arrange for a different bootable cd if it is not working even on different machine, And do remember to keep the first boot device in bios as cd rom drive
Apr 14, 2009 | Computers & Internet
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Hi pc wont start
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Comment by Beni S-P, posted on Oct 26, 2007
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
And i forgot :
check power suplay and ram???Let me know if u get help???
Nov 03, 2007 | HP Compaq Presario V2000 Notebook
Unplugged my armada m700
 - Floppy drive
 - CD drive
 - Hard drive
All users
Oct 28, 2007 | Compaq Armada M700 Notebook
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
229 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
