Question about HP PSC 2210 All-In-One InkJet Printer
Can't turn my PSC 2210 on
I've disconnected the printer from the power supply (as I often do).
Now when I re-connect it there are no lights and I can't turn it on, like there is no power. I've checked the cables and everything seems ok.
Any idea? Is there a fuse or something which may go wrong?
Thanks,
Raviv
  • 2 more comments
  • ravivt Aug 29, 2008
    Well any other device works on the same outlet.
    I also tried to replace the original power cord with another, but still - no good.
    Thanks,
    Raviv
  • Anonymous Sep 28, 2008
    I have the same problem. I beeped a couple of times a few days ago and then it was lights out. Like it simply died. Have tried plugging and unplugging, etc. Pretty bizarre behavior.
  • jimandsue Sep 28, 2008
    I am the "guest" from the last response. Will register.
  • Anonymous Sep 29, 2008
    My HP just overnight went dead, No light, and the display blink when pressing the power buttom ??
    Brigadier General:
  • 5,158 Answers
I have to start with the merely obvious first. plug something else into that outlet and see if it works.
Robert
Posted on Aug 29, 2008
HP 2210 all-in-one printer won't start.
Hi
I request you to check the power cable of the printer and remove the ink cartridges from the printer and power off the printer.
Wait for 2 to 3 minutes and then power on the printer. If still does not work check with different power outlet.
This should work.
Jan 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 will not connect to my laptop with USB cable. The cable is fine - I used it with a scanner already today. It ran the other night - however the print cartidges had dried up and needed to be...
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all-in-one on power up all the lights blink nothing else happens
connect the printer directly to walloutlet.disconnect the power chord from the back of the printer press the on button on the printer for 10 times.then press the power and cancel button simultaneously and keep holding the buttons while with the other hand disconnect the power chord wait for a minute connect the power chord back to the printer .if that does not work then took out all the cartridges clean the electrical contacts on the cartridges also clean the electrical contacts in the printer then put the cartridges back .if that does not resolve the issue try with new set of cartridges.
Sep 13, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dead PSC 2210 - can't get print cartridges out!
Try connecting the printer directly to wall instead of surge protector and see if tha resolve the issue
Aug 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
After my last print, the psc 2110 lost power and I cannot get it to turn on again.
Try resetting (power off/on) the power surge protector or try plugging your printer directly in the outlet to power on. If not resolved, power off, disconnect and reconnect the printer's power adapter. You may need to replace the power adapter. Hope this helps.
Jul 28, 2009 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 the machine is overheat and won't go
I will tell you my friend to replace the formatter board and do service the mechanism.
Jul 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Flashing power light
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP Printer will no longer scan
Hi Keithcarrol
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Dec 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 2210 all in one printer
You can't load the software that came with the printer.
HP has a Vista page for your printer. Here is a link: PSC2210 Using Vista
Basically, you need to uninstall the software AND delete the printer from your computer. Disconnect your USB cable. Power up your printer. Connect the USB cable.
The above link gives some workarounds for scanning and importing images.
Nov 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
