Question about Sony KP-53HS10 TV
Screen is green. audio is fine...
The screen on my Sony 53HS10 is green. No adjustments work. Audio is fine.
  • 70 Answers
Sounds like you have a crt bulb out better call someone out to look but it will be a little pricey
Posted on Sep 21, 2008
I have a Sony projection TV KP-53HS10. From one
It is most likely the convergence board. Rear projection TVs use three lights to display the image. The image is aligned via the convergence circuit. After many many hours of use the capacitors and resistors on the board lose their tolerances. It is very expensive to repair if you take into account the price for a new TV and the quality of the image you will be getting if you do have it repaired.
Mar 01, 2011 | Sony KP-53HS10 TV
Sony kp-53hs10 picture is cloudy and 3 colors at bottom of screen red blue and green
Look at attached photo--if it is what you have you have a convergence problem.
The KP-53HS10 uses two of the STK-392-020 convergence chips.
Both will need to be replaced and the set adjusted--parts cost on ebay is less than 20 dollars--repair consists of two things--getting at the parts and then replacing them--chips are soldered in so you need to be able to un solder them and solder the new ones in.
LET ME KNOW IF YOU HAVE QUESTIONS-I am here to help.
If this has helped out, rate this solution as I do this here for free.
SD TECH
Second picture:
Dec 18, 2009 | Sony KP-53HS10 TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
Pink Picture
You TV missing Green color ratio to produce correct colors in picture. It might needs service and adjustments in Video section .
Aug 03, 2008 | Sony KP-53HS10 TV
No video - Blinking code 5
yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Feb 01, 2008 | Sony KP-53HS10 TV
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
