Printer doesn't turn on (it has power) - Office Equipment & Supplies
  • Anonymous Sep 06, 2008
    My HP officejet 6210 printer doesn't want to turn on. I tried taking out the power supply and connecting it back to the printer. After that step it starts going through the self-test and after that shuts down. It doesn't even show any signs of lie when I press the power button. Anyone can help?
    Thanks
  • Anonymous Sep 22, 2008
    PSC 2210 printer scan copier with the same problem. I does not turn on even when plugged in.
HP Officejet 6210
Posted on Sep 07, 2008
    Brigadier General:
  • 5,158 Answers
Brand and model number to start
Robert
Posted on Aug 29, 2008
Canon 1p2770 ciss ink cartridge is not recognized
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Oct 27, 2017 | Canon PIXMA Office Equipment & Supplies
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
Doesn't print the whole page
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Oct 21, 2011 | Lexmark All-in-One Printer with PictBridge
My t10 printer , no power on?
Try a different power cable, if it still doesn't turn on then the printer has the problem canon cli8
Sep 24, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Power lights flashing,will not stop
Ok sir try to turn off the printer if it doesn't. Pull the power cable shutdown your computer then plugged again the power cable of the printer then turn on the pc and printer..If it doesn't change contact a printer technician or bring the printer to the nearest service center. Hope it helps you..
Jul 01, 2011 | HP Office Equipment & Supplies
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5270 power butoon keeps blinking and no power
Try to remove the power adapter from the printer. Then unplug the power cord from the power outlet in the wall.printmastert_62.jpg
Wait at least 10 seconds before re-plugging the printer into the power source (bypass any surge devices or power strips). Reconnect the power adapter into the printer. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for further assistance.
Jun 26, 2011 | Lexmark X5270 All-In-One InkJet Printer
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
Designjet 110 plus not turn on
do you change formater board ?or try use firmware utilit you can find it here
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Sep 22, 2008 | HP Designjet 110plus nr InkJet Printer
1,259 people viewed this question
k24674
jasbo
jasbo
