Question about Kenmore 17252 Free-standing Dishwasher
Kenmore Portable Dishwasher
I would have it attached to the sink and set it to run but it would start putting water in and then stop it would only start going again when you give it a little shake and then stop again It's been an intermitent issue for awhile, but today it won't connect at all anymore. Actually it's model # 17731
Go to Sears.com if you have a Kennmore. Under "parts," you can input your model number, which is found on the inside of the washer on the side, and then search for the part. It even has a diagram you can pull up. Unfortunately, this part for mine, and probably yours will only be available by purchasing the entire hose outfit, (about $65).
Posted on Sep 01, 2008
I have a Kenmore portable dishwasher. The sink connector(not the adapter, but the white connector that has hoses attached) spits water out of the bottom during it's entire cycle. I have used other portable...
I think that the valve assembly in the end of your attachment hose is having problems, check with Kenmore and see if a replacement one is available and if your dishwasher is new enough perhaps it might be under warranty?
May 31, 2014 | Dishwashers
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
How do i connect a kenmore ultra wash II portable dishwasher to kitchen sink, the attachement on the hose attached to the dishwasher it to big around to fit my facuet
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Aug 21, 2009 | Dishwashers
My kenmore elite leaves food all over my dishes and utensils when the cycle is over. what would the problem be
Try rinsing all of the food off the dishes before u put them in the dishwasher, also run the hottest water u can into the sink before u start the dishwasher.
Mar 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Kenmore
Make sure you run water in your sink until it is hot before you start the dishwasher. On the newer dishwashers they will fill and drain until the water is hot enough so it takes longer if it starts with cold water. Normal time for a basic wash could take about 45 min.
Oct 07, 2007 | Kenmore 15129 Built-in Dishwasher
Try cleaning out any mineral deposits from hardwater buildup. YOur local home repair or appliance store clerks can suggest an appropriate product to do this with.
Aug 31, 2007 | Kenmore 17459 Free-standing Dishwasher
Kenmore 17252 Free-standing Dishwasher Logo
188 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
