My Samsung 4095D LCD TV has about 20 dotted lines on the upper part of the screen. It is like a net on top of the screen. This happens even when I use my VCR and DVD. If I use the 16:9 ratio, those dotted lines extend all the way from left to right. Victor
ladywinn
  • 5138 Answers
SOURCE: distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Posted on Jan 09, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
SOURCE: Ghosting on LCD TV
get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Posted on May 29, 2008
  • 2336 Answers
SOURCE: New (12/2007) 1080p Samsung 46"
At this point there is not much you can do.
If this LCD is less then a year old, I would suggest to contact the manufacturers to get it fix under their warranty.
Good Luck.
Posted on Jul 23, 2008
ward_knutson
  • 64 Answers
SOURCE: Wrong aspect ratio LCD tv: Model Polaroid FLU-1911S
You cant change the aspect ratio. Polaroid built this unit with a non-standard format. Here is what I found:
Don't be thrown off by other wide-screen aspect ratios. When shopping for wide-screen displays--especially flat-panel LCDs--you may see aspect ratios such as 15:9 or 16:10. They are, for all intents and purposes, close enough to 16:9 to be considered synonymous. Unless you're extremely sensitive to geometry, it's doubtful you'll notice the slight stretching or squashing they introduce.
Sorry!
Posted on Nov 25, 2008
Red dots samsung plasma
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | Samsung Televison & Video
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
Samsung 46" pink dots
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
Nov 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
A 1inch line at the top of my lcd screen
its definately the problem of the convergence ic in your tv.
Sep 01, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
Mar 02, 2008 | Yamaha DV-S5950 DVD Player
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
