Question about GE Spacemaker JVM1640SJ Microwave Oven
Suddenly food doesn't heat
Worked fine yesterday am, clock etc. still operational...the cleaning lady gave it a good scour yesterday pm and now nothing heats up. It seems to me my folks had this happen after using some particular cleaning solution. Does that add up?
  • 2 more comments
  • rcard7 Sep 02, 2008
    GE Spacemaker microwave quit heating...everything else seems to work on the unit. Also, a bad oder (chemical, burning) eminates from the unit. We also had someone clean it within the past couple of days...not sure what could be wrong.
  • kulvin Sep 02, 2008
    Same above problem on Model # JVM1631BB002
  • Anonymous Sep 03, 2008
    checked fuses and they are good
  • lyw0766 Sep 28, 2008
    The lights and the turntable work but the food isn't heating.
I have the same problem and have figured out the following:
Most likely it is the magnetron - common problem for GE's. Replacement part list price is around $180 but you can find on ebay for about $80. Replacement is "doable" but tricky because the oven needs to be removed to replace the part. The GE replacement kit part # for magnetron and stirrer is WB27X10489. Expect a service tec to charge at least $200-$225 to make the repair so complete replacement of microwave might make more sennse...unfortunately.
Posted on Dec 04, 2008
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Model (1992) J KP6460P1B6 Doesn't heat food. Timer, clock, etc. work fine.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Aug 25, 2011 | Microwave Ovens
Not heating food
heatman101
fgghf
Apr 29, 2010 | Kenmore 63252 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Dec 10, 2006 | LG LMV1925 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
261 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
