Question about Kenmore 20172 Top Load Washer
Kenmore ELite Top Load- Calypso
Model # is 22062102 (seems long but this is what is listed under lid)
During a light load initial problem was squeaking (squealing). Cycle stopped during rinse and "LD" error appeared. Not a heavy load, so I knew it wasn't over-loaded. Removed wet and soapy clothes and removed remaining water in tub. Now cycle won't even start (begins to fill with water for 5-10 seconds then stops and several minutes later the "LD" error appears again). I have unplugged for the day and attempted to do it again. Same result...
Thank you,
Christie.
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question *%#^
Posted on Sep 23, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Calypso top load Kenmore washer. I get an LD code displayed and the washeer stops Any ideas ?
Although I haven't 'LD' in my list, I suspect that it indicates there is a problem with the lid/door lock. Either the locking solenoid or the lid lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 20, 2011 | Kenmore 24032\24036 Top Load Washer
Where do I Find the model number on my Kenmore Elite Top load washer?
The model number on Kenmore top loaders is usually printed on a nameplate along the wash tub rim opening under the washer lid. The model number has 8 digits with a prefix of "110". If you cannot locate it, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 24032\24036 Top Load Washer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 20172 Top Load Washer Logo
201 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
